DBW idle up w/ Vintage Air
I am running a 2001 Tahoe 5.3 in my 70 Chevelle with DBW. I currently have Vintage Air running external from my PCM but desperately need the idle to react to my A/C operation. What do I need to make this happen?
What pin on the PCM do I need to tap?
What do I need to send to that pin? (12V or GND)
When my A/C compressor engages the idle does not adjust for the load. Often my vehicle's idle dips below 500rpm and dies. Sometimes it adjusts. However with the cam, more often then not it will die.
by any chance, has someone figured this out with the later blue/green connectors?
motor doesn't stall, but it would be nice to have it bump the idle just a hair when the a/c clutch cycles on.
Is there anything else the computer must see for this operation to happen properly?
