Project-89 Coupe LSX Re-swap, now going turbo
#61
Guess I need to call customer service too lol Whats your plans for the throttle body, I'm thinking about ordering the matching edelbrock one but havent really seen anything about them. Currently running the stock cable and throttle body and it just doesnt look to nice.
#64
Made a little progress yesterday. Got the standalone harness laid out and everything plugged up, intake manifold and tb mounted, decided to paint that old nasty alternator, and mess with the factory wiring. In order to make the factory wiring a little easier we ended up taking out the dash.
#65
#67
Thanks for the pictures. I bit bullet and ordered the edelbrock 90mm throttle body yesterday. Should be there before I get home, going to try to retune and make it to the track on the 16th.
#68
#69
Gotcha, if you don't mind post up your results from the track if you make it out.
#73
I had to use a hammer just a bit on the tunnel up by the bell housing, but nothing major at all. The trans fits pretty nice in there for the most part. Only problem I don't like is the shifter location. Its back about 4 inches or so from where it probably should be. I know I can flip the motor mounts to bring it forward a little bit but I don't think it will bring it forward no where near what I need. I wanted the motor to sit as far back as possible for weigh, so thats why I have the motor mounts the way I do, which is what most people do. I guess they don't have this problem cause most people are autos. Only other pic I have been able to find on a fox with a t56 they had this problem as well. As far as hydraulics go I found a pedal setup out of a turbo coupe for the hydraulic clutch setup, since the mustang is cable from the factory. I have a Wilwood master cylinder I am going to try to use, I was told its the one that most rx7 swapped LS cars use. I should be getting around to installing all these things this weekend or next and I will post back with what I find out.
#74
I'll make sure to post up results, hopefully even some videos. As far as the clutch setup, I'm actually using the wilwood master and line from my rx7 swap. I pretty much copied ziptied's build on her. Leverage point might be alittle off because the pedal is alittle stiff but I dont mind. Attached a pic so you can see where the master is located.
#76
Never mind, found it: https://ls1tech.com/forums/conversio...onversion.html
#80
ver nice build...im doing this swap on my 90 hatch as well but with a th400, what alternator bracket did u use to mount it on the bottom? also how did u have the stand alon harness set up im looking to ge one as well but cant seem to find much info on them?
