4L60e transmission with cable speedemeter
Old Aug 15, 2012 | 01:44 PM
1970's Avatar
Default 4L60e transmission with cable speedemeter
Transmission guy says he can put a rear shaft housing on a 4L60e that will allow me to keep my cable driven speedometer.
Is that correct?
He says it will still have MPC?
The engine is a 2004 5.3 that I was going to connect to my old TH350 transmission.
Does this all sound correct???
Old Aug 15, 2012 | 01:57 PM
bmf5150's Avatar
Yes u can get them,look at street snd performance sells them
Old Aug 15, 2012 | 03:00 PM
bczee's Avatar
Jags that Runs has the kits also..
BC
Old Aug 15, 2012 | 03:06 PM
1970's Avatar
Can the tail housing be from some GM transmission other than the 2004 4L50e connected to my engine?
I did not think it could.
I thought the housings that have provision for speedo cable will not fit.
Old Aug 15, 2012 | 03:32 PM
bmf5150's Avatar
http://www.shiftworks.com/tailhousing.htm
Old Aug 15, 2012 | 03:33 PM
bmf5150's Avatar
http://www.speedscenewiring.com/ssw_...=index&cPath=4
Old Aug 15, 2012 | 03:34 PM
bmf5150's Avatar
http://www.jagsthatrun.com/4L60_Order.html
Old Aug 15, 2012 | 09:08 PM
LS1MCSS's Avatar
It would be a lot cheaper to get the Cable-X and use the stock speedo.
http://www.abbott-tach.com/cablex.htm
Old Aug 17, 2012 | 06:28 AM
1970's Avatar
what does VSS do?
Old Aug 17, 2012 | 06:35 AM
chevymec's Avatar
This is good info to have. Glad I saw this!!
Old Aug 17, 2012 | 07:10 AM
psiconversion's Avatar
LS1Tech Sponsor
Originally Posted by 1970
what does VSS do?
VSS stands for Vehicle Speed Sensor. It lets the PCM know how fast the vehicle is moving to allow proper shifting, Speedometer output and factors into various other calculations inside the PCM.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Aug 17, 2012 | 11:44 AM
bmf5150's Avatar
Just remember if u go with cable x,it's an additional box u have to mount and from what I'm told they are noisy
Old Aug 17, 2012 | 06:22 PM
1970's Avatar
There is only one place on the tail housing for a connection.
I can not see how two things can be connected to one opening.
The tranny guy says it can be used to drive a VSS or a speedometer cable.
If that opening is used to operate the Speedo cable the question is:
How bad will the transmission operate without VSS?
Old Aug 17, 2012 | 07:23 PM
Blue67LS2's Avatar
The conversion tailshaft housing has provisions for the mechanical as well as the VSS. That's what makes it unique; otherwise you could simply bolt on one from an earlier trans if the VSS wasn't necessary.
Old Aug 17, 2012 | 11:28 PM
1970's Avatar
Okay, why and when is the VSS "necessary"?
Old Aug 18, 2012 | 12:48 AM
71403's Avatar
If running a e-shift automatic it's required for operation. The 3rd pedal crowd can sort-of get away without one.
The path of least resistance is to run a VSS.
Old Aug 18, 2012 | 07:58 AM
1970's Avatar
That means electronic speedometer.
Is there a cost effective gauge package?
Old Aug 18, 2012 | 08:47 AM
2nd Gen Fl 'bird's Avatar
Run your TH350 and use this Speedhut.com GPS speedometer. Unless you want an original looking speedo. It might solve some issues on retro fits. Just throwing ideas out there.
Old Aug 18, 2012 | 05:32 PM
1970's Avatar
Old Aug 19, 2012 | 10:46 AM
INFRONT86's Avatar
+1, I run one in my car with the 4l60e and it is great.
