LS turbo swap in fox body questions
Swapping a L33 in my 89 notch with a 76mm master power and I had a few questions about where everyone is putting the turbo and size of radiator
I put my turbo on the passenger side. I built my hotside without the rad, hoses etc. I had to make some mods to it after I got everything installed. I would suggest that you install everything then build your kit around it. You can mount the turbo on either side there's lots of room. I bought a cheap universal rad from summit for 140 that works excellent.
I'm pretty sure my old BG kit would have worked on my ls swap if I would have welded the ls flanges onto the kit. The main reason I went ls though was to get rid of the exhaust leaks and to get the downpipe away from the plugs so I went with the truck manifolds. Make sure to post lots of pics when you do the swap.
Started on my hot side last night, ended putting the turbo on the passenger side where the battery was located.ill post up some pics this weekend of the progress.
