LS1 Swapped 68' Camaro
I still can't wait on the header fitment when you rework the 4th gen headers. Any idea when you may start that project? if not i may just break down n spend the high dollar money they cost n go from there. Or I may have found a used set of ls swap headers for $300 so I may go that route but the coating isn't the greatest on em.
I also used a 98 LS1 and modified the harness myself to save a few bucks. I have just about all of the wiring diagrams for a 98 trans am if you need any. Just send me a PM with your e-mail address and I will send them over.
I am trying to take my time and make it look good but I want to get it done so I can take it to lsfest this coming year, i'm trying not to rush it lol
You are some kind of craftsman!
The car/engine is coming along great, and you'll have the satisfaction of having done it yourself...with the help of some good friends, of course!
Although my brothers helped me, none of my friends have the knowhow to participate.
Glenn
Build is coming along great
I think that no matter how well the car is finished, that wear & tear start the moment you hit the road.
Also, that protective layer of dirt builds up after the first run!
After getting the holes elongated I stuck the adapter plate and longer flex plate bolts on that I bought from gmpartsdirect.
Next I had to work on the crossmember a little to get it to work. I basically slotted the holes and cut the secondary plate for bolt access. No support was lost since it was already trimmed factory and I just honed it out, sandblasted it and painted it. Lots of rust.
Fits like a glove.
I bought a Hurst Quarter-Stick from a friend and tried fitting it but the old holes showed from the stock shifter so I fabricated up an adapter plate to hide the holes and keep moisture from protruding up from the holes into the car and rusting. I sealed the old holes off from the bottom.
Next I took the old tank out.
I will go into detail on my fuel system later. I haven't gotten the new tank or my lines ran yet.
But she's getting there. Slowly but surely.
