Manual Trans for LS in '66 A-body?
Old Nov 27, 2012 | 08:29 AM
daturbosix's Avatar
Restricted User
Default Manual Trans for LS in '66 A-body?
my dad wanted to do a T56 in his '66 gto, but then read that you have to cut and clearance the trans tunnel. he doesnt want to do that, nor do i want to let him do that to that car.
i read something about smaller bodied aftermarket T56, magnum t56? or some kind of tko600 that was used in a 70 camaro swap.
anyone have some experience with putting a banger in a-body without floor modifications? and let me clarify, i dont want to use a 4-speed...im looking for something with atleast 1 overdrive gear
Old Nov 27, 2012 | 08:49 AM
garys 68's Avatar
Richmond 5 or 6 speed will fit without mods.
TKOs generally need the tunnel cut.
I went a different rout, a T10 4 speed with 3.42 1st gear and a 2.73 rear. Almost like OD. Might even swap out for a 2.56 rear.
Old Nov 27, 2012 | 09:35 AM
1967BuickGS400's Avatar
I went with a T-56 from D&D performance for my 67 GS400. I did have to modify the tunnel but it really wasnt that big of a deal. All you have to do is cut down the center of the tunnel and down to the floor at the fire wall. My brother and I had it done in an hour or so and it looks stock.
Old Nov 27, 2012 | 10:30 AM
bczee's Avatar
You can also gain more trans tunnel clearance by keeping the Engine low and forward. Standard or +1" forward mounts.
This might help get more clearance.. but will lead to a different set of issue to work around (oil pan, crossmember, front accessories, steering box, etc, some will a problem and some will not).
Many will use what the call the T-Cut to make a simple cut, spread and fill in to enlarge the tunnel where needed. BRP Hot Rod used this and had it in a web artical on there side in the past.
just a thought...
BC
Old Nov 27, 2012 | 11:09 AM
pairof69s's Avatar
hey what flywheel did ya use with the T10...sachs 1050?
Old Nov 27, 2012 | 11:17 AM
garys 68's Avatar
Yes, although it's a 26 spline input so a standard LS1 flywheel/clutch would work too.
Old Nov 27, 2012 | 04:57 PM
pairof69s's Avatar
i'm asking cause i'm looking to put a 4spd behind a LQ9 in a 69camaro, i've done all the research, already have the sachs 1050 flywheel but was hesitant to use it due to it being so damn heavy..! although it's going to be 90% street car it'll still see 6500 regularly...is it a bad idea to use this flywheel above 5500 rpm...? I guess I need to get a steel bellhousing..
Old Nov 28, 2012 | 07:21 AM
garys 68's Avatar
Interesting question, is a thicker, heavier flywhhel more or less likely to come apart?
But if I was dropping the clutch at 6500 rpm, I would definitely get a really good bellhousing.
Old Nov 28, 2012 | 12:10 PM
pairof69s's Avatar
I'm just wondering if the 65lb flywheel would have any i'll effects on some aggressive driving.? I probably won't be dumping the clutch at all really
Old Nov 28, 2012 | 12:36 PM
garys 68's Avatar
26 lbs for the flywheel, 20 lbs for the pressure plate. Greater rotational mass equals a slower spool up. But coming out of the hole will be an advaantage. Flywheels store energy, so in drag racing the weight will be an advantage.
Old Nov 28, 2012 | 02:03 PM
rockytopper's Avatar
Have you consider the gear vendor under/overdrive with your 4 speed trans?
