90 mustang 5.3 swap
workin on getting a 5.3 in my 90 hatch fox body and wanna do some minor motor upgrades before runnings it...what is a good cam to run in the ls motors, planning on running nos for this season then turbo set up over next winter? have herd about hot cams, ms3 and the trex cams but not sure on what ones are best suited for street/strip race type situation.
also i am looking for a wiring harness to get the motor to work with a th400, is there a company or reliable source where i can get one from? about how much do they run?
Welcome aboard the Abomination train!! lol! Since your new and from Michigan ta-boot, ill just throw out some info. Bill with I think its BP does a awesome job on stand alone harness's but they're several sponsors on this forum you can contact with your needs for the harness.
Sweet another ls fox.for the cam contact martin@tick performance.as far as trans wiring youll really only need the vss,but iirc youll have to use the dakota digital pass thru vss on a th400.there are other options but they are more expensive
dmracing im in canton
the trans is rev man valve body so i dont think i need any wiring for it other then the break to my knowledge
i will look into the wiring harness thank you
trying to get pictures one here...do i just copy and paste or is there a process i have to go thorough
Carb, heres the build
https://ls1tech.com/forums/conversio...rp-mounts.html
