55 chevy swap
Old Feb 8, 2013 | 09:35 PM
rlgood's Avatar
Default 55 chevy swap
Possibly looking to do a ls swap into a 55 chevy and not having any luck searching on here so any links to any tri 5 swaps would be greatly appreciated. Thanks
Old Feb 8, 2013 | 09:44 PM
LS1NOVA's Avatar
What kind of info are you looking for. I did a 56 swap last year. Pretty straightforward.
Engine swap plates, frame mounts, and trans crossmember from Ecklers. Harness from PSI. Cut the trans mounts off the frame. Radiator relocated in front of rad support with a Northern radiator. Vintage Air unit and ac brackets from Kwik Perf. F body accessories with frame notched for alternator. F body manifolds fit perfect.
The owner of this one was going after stock like appearance. Coils are behind the air cleaner and stock throttle body is under there too so still EFI.
Heres a link to my photobucket, browse around on there.
http://i1025.photobucket.com/albums/...Chevy003-4.jpg
Old Feb 8, 2013 | 09:55 PM
rlgood's Avatar
Mainly wanted to look thru any build threads to see what problems others had run into. One question for sure is oil pan, does the lh8 pan work on these or does it hang to low like on the chevelle? What pan did you use?
Old Feb 9, 2013 | 05:41 AM
LS1NOVA's Avatar
Yes, LH8 pan works good, doesnt hang down.
Old Feb 9, 2013 | 07:27 AM
Old Geezer's Avatar
Default try this...
https://ls1tech.com/forums/search.php?searchid=21180555
Also, look over at www.trifive.com.
Also, the LH8 pan is from an H3 Hummer. That pan is well below the frame on my 55.
Old Feb 9, 2013 | 06:37 PM
RJHall's Avatar
Hi, we did an LM7 5.3 in our 55 2dr post and if you go thru our build it will explain how we did the LS1 install. Not hard at all
Good luck
Randy
1955 2dr. Delray LS1 5.3/munice 4-speed
http://www.trifive.com/forums/showthread.php?t=72541
Old Feb 9, 2013 | 07:09 PM
the_merv's Avatar
Veteran: Air Force
That's cleaaannnnnn...
Old Feb 9, 2013 | 11:35 PM
rlgood's Avatar
Mr Hall thanks for the link to your build, looks like you did a great job
