TR6060 question
Old Feb 14, 2013 | 04:02 PM
50adrod's Avatar
Default TR6060 question
i am confused and could use some help. I am installing a supercharged LSA 6.2 crate engine from GM performance. I ordered a tr6060 six speed trans part number 24258817 from GM performance also and receved the trans but it is not what I expected. the one I recieved has the shift rod coming out t he back
and the place where the remote shifter goes looks like this
all the other 24258817 transmissions I looked at have the remote shifter on the top like this
http://www.crateenginedepot.com/TR60...17-P18242.aspx
what part number should I have ordered?
Old Feb 14, 2013 | 06:45 PM
bigmandengo's Avatar
You should have got a t56 magnum. It is basically a tr6060 setup for retrofit applications.
Old Feb 15, 2013 | 06:24 AM
50adrod's Avatar
Yes I know, but I am building this for a customer and he wanted to get the engine and trans from a dealership. the dealer will swap it out for a trans from a 2010 Camaro wich I believe is a TR6060 also, is there any difference between the two other than shifter location? thanks
Old Feb 15, 2013 | 08:48 AM
74modified's Avatar
The 2010 Camaro SS is a TR6060 and has an external shifter.
You can mount a shifter on the detent cover (McLeod),
https://ls1tech.com/forums/conversio...68-camaro.html
but if you need the shifter further back, you have two options, build a custom shifter - my way
https://ls1tech.com/forums/conversio...get-build.html
Or- change the mainshaft and tailhousing - a nice build
https://ls1tech.com/forums/manual-tr...body-pics.html
Old Feb 15, 2013 | 10:21 AM
btlegacy's Avatar
Here is another example of a custom shifter mount
https://ls1tech.com/forums/16814714-post92.html
Old Feb 15, 2013 | 11:37 AM
74modified's Avatar
Nice BT, saw your video, looks like you built a fun ride!
Old Feb 15, 2013 | 11:44 AM
jsanford's Avatar
Looks like it would work fine in a forward mount position. I looked at one, but didn't get it.
http://www.ebay.com/itm/Core-Hurst-S...sories&vxp=mtr
Old Feb 15, 2013 | 11:51 AM
74modified's Avatar
That looks like a good part. I havent measured it, but I think the "ball" end that goes down into the shift mech needs to be a little longer for a 6060 than on other Tremec transmissions.
Old Feb 17, 2013 | 08:29 AM
50adrod's Avatar
thanks for the input, the LSA motor has a 8 bolt crankshaft and I read the TR6060 from a Camaro will not work. I ordered the install kit from GM performance that comes with the flywheel and the dual disc clutch setup. I think I will order the shift rail for a Camaro TR6060 (it should hopefully be the right length) and replace the one in this trans with it and then get the Mcleod shifter. if anyone knows why this would not work please let me know.
thanks again
