New Internal Fuel Pump Option???
Has anyone used this setup yet? I'm thinking this may be a great option for me as I have a new reproduction tank currently in the car and I'm having a hard time spending $$$$ on a SS tank with internal pump.
My only concern is that it looks like the return is straight back into the bucket...wouldn't the fuel get hot being continually recirculated like that?
Jon
Psi
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
The height of that thing is adjustable to something like 6 to 15 inches. To get clearance at the top of the tank you can weld in a recess. There are places that sell them premade.
http://www.tanksinc.com/index.cfm/pa...rod/prd370.htm
Only issue with that kit is the price. I thought the tanks inc insert was pricey,
http://www.tanksinc.com/index.cfm/pa...=cat/cat61.htm
But $550 for the aeromotive set up is steep. At least it has a good pump
All of these fuel sump things just slow down the movement of fuel. If you are doing NASCAR turns while running on fumes then a dual pump and surge tank is the ultimate solution.
Someone needs to buy that and tell us how it works.
My installation did not include the kit now offered, but was very straightforward and has worked perfectly (car is just under 600 at the rear wheels).
Aeromotive is a bit pricey, but you get what you pay for and their customer service is second to none (ask for Brett).
You'll never regret this install....good luck
The idea of the foam is that it fills up like a sponge and under cornering, etc, the fluid will weep out slower than if no sponge was there surrounding the pump. I agree with popn on the surge tank idea but this seems like a simple solution. Would be interested to know if that quantity of foam is large enough to hold enough fuel to prevent surging. I would think some foam is better than no foam.
Jon
PSI
That tanksinc setup was actually the other that I was looking at...I guess I'm trying to find out which would work better for casual autocross use.
Also how much HP/Tq would the tanksinc 400L pump handle? Has anyone used it with success? I wouldn't mind saving the extra $150.
That is one of my concerns. I can only imagine that it is the return into the foam cylinder that prevents the starvation.
Jon
PSI
Thanks for your opinion. Maybe just put foam in a similar fashion around the cheaper tanksinc setup and save $150??
http://forums.hybridz.org/topic/5810...as-tank/page-2
If you don't mind cutting a sizable access hole you could probably form your own bucket from a block of fuel cell foam then install a GM fuel pump insert yourself.
Quite a few places sell access plates as well as foam.
http://atlinc.com/pdfs/Design-Helper...Ring-Guide.pdf
