5.3 swap into a 68 chevelle, HELP!!! tons of questions
Im sure this topic has been beat to death, but maybe not for my specific year model car. We have a 5.3 out of a 2002ish year model chevy truck and 4l60 tranny from the same truck. We have sent the harness off to be reworked so the electrical part of this swap is under control. Our questions are concering all the parts we will need to actually make this motor work in my car as far as intake, oil pan, headers, etc... im sure the list is pretty long and ill never think of it all. Im looking for someone who has done this swap and can give me a list of what all it will take and some venders to get it from if thats not too much to ask.... any help is great and thanks in advace! car will be stock height and has an ss hood on it that we are keeping
if you look at the stickys on top there is one specific to a-bodies
my 64 chevelle is done , holley accesorys drive , 200 4r trany 96 impala fuel tank and pump ly6 engine with stock harness and e38 computer , l99 cam ls3 intake and injectors
headman headers
plasma cutter and welder was used in building my car
i would sugest the holley oil pan i am useing the gm musclecar pan an its low by about 2 inches
headman headers
read through these..they will answer all your questions.
https://ls1tech.com/forums/conversio...2-gm-body.html
Pretty much everyone with a build thread has done the swap, and as mentioned your setup is going to be the same as all the others in terms of what you are working with. Factory front disc vs front drums cars having the brake distro block in different places are all that pops to mind as something to watch out for, and that's only when buying headers (on disc cars the block is on the inside surface of the driver's frame rail, right where your headers need to go). Easiest approach would be to find a build you like and more or less copy it.
