UK four door saloon LQ4
This little lot was collected by some local mobile scrap metal collectors
It then took me a couple years to get to this stage
you can see how much room I have to work in - see the shell in the garage I had to lay the tubes out cut them with the notcher and tack them together in all inside the shell inside the garage!
I then had the chassis welded at http://www.robinson-race-cars.co.uk/
as I had never welded anything up till starting this and didn't fancy falling thru the floor whilst driving along!
I also (once I had paid off the credit card) got some front lower arms and four link tubes
Megasquirt II
I had up till this point intended to use a 357 SBC but after reading an article in RPM magazine I was corrupted by the idea of an LS and after reading the Car Craft articles and turbo'd truck motors in particular
So I got this from http://www.lsxp.net/
I pulled one of the heads the other night on a day off which has a been a rarity lately and was pleasantly surprised
That's the cars front wing on one side of the engine and the garage wall on the other! Tight!
I also had a front plate from http://www.aeicnc.com/ arrive last week so maybe at some point I can get the engine mounted in the chassis!
1 Post
I've gotta give you BIG props for tackling a project like that, given the small space you have to work with... You're either insanely determined - or perhaps just insane...
Good luck with this build, I'm going to be keeping an eye on this one. I'm betting that it's going to turn out great!
1 Post
I'm bit intrigued by this build, so I looked up 'Carlton GSI' (because of course we don't see those stateside). I'm guessing that your car originally looked something like this??
I also found that there's a little bit of information about the car http://en.wikipedia.org/wiki/Vauxhall_Carlton. It's definitely helpful that the car started as a RWD platform. What are your plans?? Are you going to make it obvious that a V-8's been swapped in, or are you going to try to keep it relatively low-key?? Heck, you might not even get past MoT with the swap (not sure what's involved with that inspection), so perhaps it's going to be a track-only toy... That "jungle gym" of bars shown in your 2nd post shows that it won't be an entirely-convincing sleeper... (If you are able to drive it on the street though, & if you keep the exhaust note pretty low-key, I'd bet that you'd be able to really surprise those who perhaps aren't looking too closely...)
Good luck with the build!!
Didnt the lotus edition do 175mph in the early 90s? I think it was based on the Cadillac Catera platform?
http://automobile.wikia.com/wiki/Lotus_Carlton
It was faster than the corvette of the same era, so people probably won't be surprised if its fast.
Looking at it it's based on a VN Commodore from Australia. Although reading Wikipedia I'm not really sure who came first. http://en.wikipedia.org/wiki/Holden_...2.80.931991.29 awesome looking build by the way!
