what spring rate on aje kit should i get?
im going to be ordering my ls1 k-memeber kit. im just really unsure which spring rate to choose?
this is the kit im going to order:
UNIVERSAL MOUNT K-MEMBER, CHOICE OF ENGINE MOUNTS, BUSHING A-ARMS, COIL-OVER KIT WITH CHOICE OF SPRING RATE, CASTER CAMBER PLATES
any tips or any reason why i shouldnt get this kit?
is there anything else i should be picking up from aje while im getting this kit?
thanks for all the help and any input you guys can give!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yep your on the right track but you forgot the AJE trans cross member for what ever trans your useing........now your motor and trans will sit at the right angle..
F-body oil pan fits perfect......Dynotech headers fit great .....the Kooks are nice but the drivers side dumps right at the trans cross member mount.......if your on a tight budget you could try these....
http://www.jegs.com/i/Hedman-Husler/...ductId=2167916
I`m on my 2nd conversion and used AJE k-member with LS mounts and trans cross member and both times i have been vary happy..........If your useing a all aluminum motor i would go with the 150 pound springs.........i went with 175lb springs with my ls3 and wish i would have gotten 150lb springs.......the higher the number the stiffer..
thanks booboo. i was thinking of making my own trans crossmember but for the price i might as well just get it. my motor is alum so ill def get the softest ones. youd say the dynotech headers are the best?
14-150 or 14-175 are ideal for street strip cars with reduce weight in the front end. Yes, Dynatechs are a good choice, it's what I am using 1 7/8's. For their cost they should get 02 bungs but don't, you have to put them in yourself.
On my 90 notch with my alum. ls3 i went from 14-175 to a 12-150 and it seems way better now but i can`t put the car on the ground yet............yes Dynatech LS/fox conversion headers..........use a 98-02 LS1 f-body oil pan with the AJE k-member with there LS motor and trans mounts....
