Super Sensitve Steering
I swapped a 6.0 lq4 into an 86' Suburban and has been running and driving great but the steering at highway speeds is light and super sensitive. I'm using the stock 1986 steering box with the lq4 power steering pump. Also a note....I am using vacuum brakes so I have the hydro boost capped off. I am thinking the LS style power steering pump puts out more pressure than the original 1986 pump making it more sensitive and with the hydroboost capped off it ups the pressure even more. Anyone know if there is a fix or anyone had this problem before? I'm just trying to get a heavier feeling steering wheel at highway speeds so 1/4" turn of the wheel doesnt make me change lanes.
This should help:
http://www.borgeson.com/xcart/catalo...p-1-c-133.html
You could also switch to a larger pulley on the pump or a smaller (Underdrive) pulley on your crank in order to reduce the pump RPM's.
-matt
-matt
If you still have your old PS pump laying around you can take the valve out of the back (where the pressure line attaches to the pump) and put it in the new pump so that your pump matches the the pressure the box was designed for, just like when you had the old small block in it. Careful, there is a spring in there and once that last thread lets go, everything likes to pop out at once. I think its a 1" head maybe, I remember I didn't have a socket big enough for mine and had to use pliers...
I dont have the old pump anymore but I'm sure that someone has one laying around and if not they are around $30 new from Autozone so I will give that a shot. So just take out the one from the sbc and it will screw right into the pump for the LS style? Also, did you use the spring and everything from the sbc?
Is it a different size or something because my pressure hose fit right up to the LS style pump and it is a stock 1986 pressure hose. It was the same fitting size I just put a brand new hose on it when I did the swap.
As far as pressure of the new and old, yes.. the newer pumps put out a few hundred PSI higher that the older SBC ones.
Here is a thread on this subject
https://ls1tech.com/forums/conversio...truck-etc.html
BC
BC
The later 80's boxes use o ring fittings instead of the older double flare type. I use them on my 67-72 swaps because they are a direct fit and the lines are the same as the LS pumps. They are also fewer turns lock to lock so they drive a little better. I've never had one that felt too sensitive though. Are you sure your alignment is correct? That can make them feel touchy too.
