Where to find pcm connector pins
Where would i be able to find the pcm pin connectors? There are a few wires in my harness that are 2 short and like to put a new long wire in its place instead of splicing wires together.
Which ECM?
eficonnection . com makes it pretty easy to find connectors & pins, but many of them require a proper crimping tool which is rather expensive. I bought some service/repair crimpers off ebay to do my crimps. Each type of terminal can require a different type of crimper. You can find the pins a bit cheaper on mouser . com.
I needed 2 pins once, and I just went to a junk yard, cut off a handfull of wires from a pcm harness, and pushed the pins out of the connector...
took them home, soldered the short wire I got from the junkyard to a longer one, added some shrink wrap, and cut the newly extended wire to the length I needed
worked great...simple and easy, no need for a crimp tool
I totally forgot about efi connection id have to check that out, i have the crimping tool already for termainls, i also have a bunch of pcm connectors with the pins in them but i rather install a new wire and pin instead of soldering them.
