getting ls mustang into high 11s low 12s
Old 03-05-2014, 10:40 AM
Joe Lluvia Avila's Avatar
Default getting ls mustang into high 11s low 12s
i have a 89 fox body that i want to be able to get into the low 12s high 11s. what extras do i need to get it there? I hit 13.3 @ 109 with stock converter.
Mods:
Engine: 04 5.3 cammed (285LR HR13 - 235/243 .621/.624 113LSA)
36# injectors
ported/polished stock TB
virgin 706 heads
PRC Dual Valve Springs good up to .650
Comp Cam Chromoly 7.4 push rods
Custom Tune with tow/haul button
Tranny: 4l60e stock converter for now. corvette servo, transgo hd2 shift kit, z pack clutches, "the
beast" sun shell (will be installing a TBSS Circle D 3200 stall in the
next few days)
Rearend: 8.8 trac-loc w/2.73s
Tires: 245/50/16 street tires
Old 03-05-2014, 11:09 AM
5.0 LsX's Avatar
Tires, stall and gears. 11's all day, possibly 10's depending on setup
Old 03-05-2014, 11:33 AM
Sleeperls's Avatar
Id change the rear gear imho.
Old 03-05-2014, 11:45 AM
Im planning on going with ford racing 4.10s full spool or just ford racing 4.10s with trac-loc.
Stall will be changed out to a 3200 - 3600 Circle D this weekend.
Old 03-05-2014, 12:50 PM
onequiklx's Avatar
A good stall will help alot. then combined with a steeper gear and sticky tires u would be amazed how much it would pick up. Then add about a 150 shot and u would be in the mid to low 10s. main thing id focus on is getting it to leave good. The more u pick up in the first 60 feet will help u acheive a better et.
Old 03-05-2014, 03:54 PM
rouseyss's Avatar
Yea those 2.73's aren't helping at all. Get some gears stall and sticky tires and above all seat time in that car. You should get there
Old 03-05-2014, 04:09 PM
23_hellfox_23's Avatar
Agreed on everything everyone is saying!
Should run solid after that stuff is changed.
Old 03-05-2014, 05:09 PM
speer13's Avatar
you never mention suspension? I'm not thinking you have 10's in that set up but 11's are not out of the question... you never mention 60 ft times..weight...suspension mods all of which can get a stock 302 deep into the 12's or better.... The tires and gearing you have def aren't going to help things as others have said
Old 03-05-2014, 05:17 PM
stock suspension, no subframes...i'll be happy with getting mid to high 11s N/A
R/T 0.672
60' 2.109
330 5.907
1/8 8.809
MPH 84.90
1/4 13.345
MPH 109.60
Old 03-05-2014, 05:19 PM
dmracing's Avatar
R/T 0.672
60' 2.109
330 5.907
1/8 8.809
MPH 84.90
1/4 13.345
MPH 109.60
You need suspension and tires for sure
Old 03-05-2014, 05:27 PM
5.0 LsX's Avatar
you will also need subframe connectors and once you put the tires on, you will need trq boxes shortly lol
not to run the times you are looking for, but to keep the car intact!
Old 03-05-2014, 05:58 PM
dmracing's Avatar
True, you rip out the torque boxes, your in trouble. Remember the 5.0 only made 225hp.
Old 03-05-2014, 06:45 PM
murphinator's Avatar
trapping nearly 110 (109.6) shows it has low 12's power right now , the 2.1 60 foot time shows why your not running low 12's lol
Old 03-05-2014, 07:45 PM
redtan's Avatar
If by 11s all day you mean 11.8-11.9 then yes I agree. Ain't no way he's getting anywhere near low 11s (much less 10s) with just those 3 non power adders.
Old 03-05-2014, 08:04 PM
ASSuming On The Tree
audacious nick's Avatar
Easy:
Get some tires, stall, suspension, and seat time. Done.
Also, I don't know if a cam like that is optimal for your 5.3l
Old 03-05-2014, 08:08 PM
The cam is an aggressive cam that came out of a 6.2 vette. Its big for a 5.3 but it can handle it. Just need the right stall for it. Drive train parts are all upgraded to handle that rpm. I have my shift point set to 7k for 1st and 2nd and 6900k for 3rd.
Old 03-05-2014, 09:04 PM
this is my idle clip...i'll try to get my run at the track uploaded.
Old 03-06-2014, 09:07 AM
usdmholden's Avatar
To run a mid 12 all you need are:
1) rear gears, 3.55 or 3.73 would be good, 4.10's would work also
2) drag radials, Nitto 275 50 15s or equivalents for your 16" wheels
3) good, weld in, subframe connectors would help but are not part of the bare minimum list
4) practice launching
If you put in a 4.10 you probably would not need a converter, especially if you pull out a couple hundred pounds.
If the engine is not making power at 6900 or 7000 RPM, you are probably slowing yourself down by shifting so high.
A 109 mph trap could put you in the 12.2's if your setup was correct and you got good at driving it.
Old 03-06-2014, 09:11 AM
usdmholden's Avatar
I missed the 235 cam, 4.10 plans and 3200 stall plans.
With a good drag radial and subframe connectors that thing should run low 11's high 10's if you learn how to launch it and get your shift points correct.
Old 03-06-2014, 09:15 AM
my cam makes power up to 7200 rpm. I dont think my 2004 5.3 truck intake will feed my engine at the high of rpm. so my next upgrade would also include the Holly Hi-Ram intake.
http://www.summitracing.com/parts/hl...Fahj7Aod50wA7Q
Quick Reply: getting ls mustang into high 11s low 12s
