Evap system??
http://paceperformance.com/files/pdf/19244807E-ROD.pdf
THe only thing I am not sure about (and i will be tackling this soon for the olds im doing) is the fuel level. You do need to tell the ECU what the fuel level is, its not supposed to run the EVAP monitor unless the tank is 1/4-3/4 full, it accounts for fuel slosh etc etc...What im not sure about is if you can trick the ECU with a resistor to say hey its alwyas got 1/2 tank of gas. THe ECU MAY have programming to go hey now, its been 1/2 tank for 500 miles, thats not cool, and set a check light for the level sensor.
The options for fuel level are as such.
1. Install a second sender for the ECU, but then youll need to run all that wiring etc etc.
2. Change your sender for the later OHM sender, again that may require mods that can be a PITA. and then youll also have to get your stock fuel gauge recalibrated for the newer sender
3. Get a conversion device that takes the stock sender say 0-90 ohms, and converts it to 40-220 ohms, I think thats the range of the truck fuel sender. They do make programmable conversion boxes to do this for actual fuel gauges. They arnt cheep, couple hundred $$ but it saves modding the tank, adding a sender, etc etc
Thats pretty much it. Wire it to the ECM and it should be good to go.
Mark I might need to hit you up for where all the lines go since someone had already hacked them off.
