Ls1 s14 240sx road race car
What's up Ls1tech. I have a 1997 240sx with a tube frame front end and ls1 swap. This car has been through numerous engine set-ups and has been a track car for a long time now. All of the fabrication was done by us, at Defined Autoworks. The engine is an ls1 from a 2002 camaro ss. The ls1 is a mild build and makes 393.3 hp, and 360tq to the wheels on a dynojet dyno. Im just running an ls6 intake, ASA cam, ls6 valve springs (soon to be changed), ls7 lifters, ported stock TB, and Hooker 1-7/8 long tube headers. All of the other modifications are just to strengthen the oil system. I am using a super speedway Nascar radiator, and oil cooler set-up. The cooling system is bullet proof to the max, I cant get this car hot no matter the outside temp. Im also happy with the weight of the car, it's 2630 without driver. The car ended up being %53 front heave with the driver and a rear ballast box, which is what I like to see with static distribution. The n/a 3 rotor was rear heavy and gave the car some weird handling characteristics. All in all I like the Ls platform and can't wait to keep evolving it. My main goal is to compete in small enduro races. So power will not be a main concern. Reliability will rule all my modification decisions.
Here is the build of the chassis, and more on the history of the car's build.
http://nissanroadracing.com/showthre...light=EfiniRX7
I sold the rotary a year ago, because I was offered a price I could not turn down. I was then in need of an engine, so ls it was. I just wanted to try an Ls out and see what they are all about. I am impressed with the mid corner grunt the engine makes. Im still a bit skeptical with the reliability compared to my n/a 3 rotor, but it's proving to be a strong engine so far.
![](http://i184.photobucket.com/albums/x112/EfiniRX7/IMG_3840_zps58359aec.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/IMG_3842_zps4d93133b.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/IMG_3844_zpsb543ca12.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/photo-206_zpscaf03c9e.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/photo-202_zps2ce99a3e.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/DSC_0166_zpsad9800af.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/DSC_0169_zps688b00bf.jpg)
![](http://i184.photobucket.com/albums/x112/EfiniRX7/DSC_0172_zps505866a5.jpg)
On dyno at Dyno Tune motorsports by Columbus Ohio.
Idle video, Im running the ASA cam. This cam is amazing on the race track, I love it.
Another video of first start-up. The tube front makes maintenance a dream.
I have some on track videos I will post, and the dyno chart. I am really happy with how the car performs on a big track so far. Im really surprised at how it performs on an autox track. I will be updating this thread as the car evolves. Valve train upgrades are on the list to complete before spring arrives.
![](http://i184.photobucket.com/albums/x112/EfiniRX7/IMG_3838_zps3bb985d6.jpg)
Super clean setup. These GM motors keep impressing me the more I research. Been in the 240sx scene since 2000 and have gone from Ka; SR fully built; 800rwhp 2jz setup. Though my car is still under the knife I have no doubt it will be a stout setup with 5.3 LM7 setup.
Can't wait to see more progress on your setup. Keep up the good work on her and so glad to see someone driving their 240 for once instead of parking lot pimping with 19" rims and super stretched tires and -11 degrees of camber like what it's become.
I have to ask, how did you end up choosing the ASA cam? Is it for it's ability to run stock springs and give long spring life? Cuz otherwise I don't see how such a low lift cam is beneficial?
I would understand on a daily driver it would be nice to get 100k miles out of your $60 springs instead of having to replace $250 springs every 15k miles. But on a racecar? A mid 600s lift cam would provide a huge power benefit everywhere in the range over low 500s.
Max Hp is low on the list of priorities for this engine, reliability and part availability are much higher on the priority list. I do know you can make so much more power with a custom grind cam. I know a cam grinder can make me a cam ideal for road racing, but the ability to go to jegs and buy parts in stock on the shelf is important. If I have a failure on the track I want to be able to buy parts same day if possible (i.e. if I break a valve train component in qualifying and the engine can continue, then Im still in the race with in stock off the shelf parts). Also another thing I watch for is power per cubic inch. The more power per cubic inch I make, the more stress per cubic inch I make. I only want as much power as I need to keep reliability up. Since most classes in NASA are power to weight based taking weight out is more advantageous for many reasons. Less weight means less stress on the brakes, tires, and steering components. Less weight also makes the car change direction faster/better. If I put more tire and aero on the car to run super unlimited then I would need an engine making all of it's possible HP.
I love the car and it's purpose built so that makes it even better. I'm an S14 fan myself. I currently own two s14's and one s13 coupe. Two of mine are Ls swapped. I would love to see a pic of the under carriage to get an idea how you ran your exhaust.
