65 Skylark Lr4 and 4L65 swap
#61
Cool project, gotta be hard moving around and finding time to work on it.
I bought my first new car in 67, 67 Camaro while overseas, I couldn't wait to get home to drive it.
I have a 65 Special sedan, 6.0, turbo-I used coilovers on all 4 corners, makes ride height easier to adjust, but also needed the room in the rear for the 4" single exhaust.
#62
Looks like it applies spring ring pressure to the inside pad when the cable is pulled tight. I'm unsure how well it works at this point as my front cable is stretched out of adjustment and I bent a rod up for the left/right cable equalization.
Id like to replace all of the cables with new, or possibly work in a console integrated brake handle to free up room in the kick panels for speakers.
Right now now however I'm at a holding point until I get a speedometer that works. I'm leaning towards ditching the Dakota digital signal to mechanical Cale converter box and going god probably from speedhut.
