another is300 ls swap
http://www.painlessperformance.com/webcat/60217
wire is to be spliced into the circuit from the AC switch to the AC compressor.
For the fuel pump you could just take the 12v lead and power your relay with it.
You can control the fans via the LS harness. It has outputs to trigger fan relays based off of the coolant temp sensor.
You should be able to find all that Jim(parish) posted up on the build here, somewhere.
We put a smaller(physicallly) battery in it, to give us room to mount the factory pcm in the engine compartment.
We had to flip the shifter linkage from the pass, side to the drivers side to get teh factory auto shifter, to run the 4l60e.
The gas pedal was a pain in the ***, if I remember correctly, it has been a few years, ago.
It didn't have air conditioning, there was some reason why, and can;t remeber now, but it made things alot more complex. It had nothing to do with the wiring part of it tho, I'm sure of that.
I just pulled an LM7 w/4L60E, and am working on my swap as well.
Here it is
