1969 Chevrolet El Camino SS396. LS1, 4l60E trans.
Hello! I'm doing a LS1 w4l60E trans in my 1969 Chevrolet el Camino SS396.
I have a budget. And my question is ; Can i use the original SS396 Radiator with lS1 fans as cooling on my project? will it hold, be enough cooling? This is just temporary until i get more money for a aliminium radiator. Everything i do now is as cheap as possible , just to get it running. And anyone who has a tip on a cheap gas tank with pump and sending unit? Im thinking about this one: http://www.tanksinc.com/index.cfm/pa...rod/prd383.htm with the pump and sending unit. Is this a good price? I'm very thankful for answers! I'm 19 and live in Norway and doing the build on my own, so i need help. hehe
Best regards Hans.
Best regards Hans.
There are alot of cars running stock radiators, with the LS1 fans you should be good unless it gets really hot there. I went with a Griffin LS swap radiator due to the Texas heat.
It's not installed yet, but I also went with the complete Tanks Inc setup based on other threads on the forum. Seemed like the best choice for the money.
Mike
Mike
I used the stock radiator, and that is the tank I wished I would have went with from the get go. I did an in line fuel pump with a stock sumped tank. But have already had one pump fail and will end up doing the tank you mentioned in the long run anyways. My car is a 72, check out my build thread, I can answer most anything you need el camino wise with the swap. https://ls1tech.com/forums/conversions-hybrids/1631831-1972-el-camino-ls1-swap.html
I recessed top of a new tank for my 76 skylark to keep a factory 06 silverado pump assembly. I made a box 6x6 4 inches deep on bottom of tank for pump to be in. Its the lowest point of tank. About $175.00 into new tank & pump assembly. $5.00 scrap metal. Nothing special but new/ built cheap.
Thank you for answers all! helped alot! Now i have the fuel delivery , fitment, cooling and exhaust ready (in my mind) hehe. But! i have a problem with the accessory drive! I know the altenator will be a problem with the steering box. I'm going to drop the ac and move the altonator over the p/s with a bracket. But where can i get the bracket and belt? and the balancer didn't follow when i bought my engine. Where can i see that my waterpump, altenator , p/s and idlers is for camaro or corvette? And where is a good place to buy the bracket and belts? would be nice to know a good place to buy swap parts. Thanks.
Check out Lsbrackets.com have different options. holley does too. I think stock truck stuff fits but you change steering pulley to a Dorman 300-130 for clearance.
im getting ready for my 2nd swap in 88 squarebody 1/2 ton 4 door. I bought a underhood cavalier fuse box as Im leaving under hood of truck. get it for 95-05 cavalier. It has more than needed but extra dont hurt. $20 at local yard. i just rearranged stuff for fuses. part of them is going to have 12v all time others are going only to be 12volt ignition/run power for injectors, mass air flow, oxygen sensors, coils, etc. looks like its going to work out good.
