LS into '94 firebird, what radiator hoses?
i'm finishing up my swap right now and trying to make sure i've got all the parts i'll need. does anyone know if i'm using the stock (LT1) radiator and a stock LS/fbody water pump, what radiator hoses will i need to use? i've got stock LT ones now but if i need something else i want to get it now!
thanks guys.
thanks guys.
do you have access to the car you got the engine from? Maybe you can just take it's radiator. Worse case, look around at Rock Auto to see what hoses look close enough to work. I ended up buying a radiator anyway because i put a screwdriver through my old one by accident (note to self: screwdriver != chisel). It cost something like $109 delivered...
I am running stock Ac delco Ls1 Fbody hoses. If using a Lt1 radiator you have to plug the engine oil cooler port. Also look for a 98 Fbody upper hose if you are not going to run a power steering cooler. Later models had a two piece upper hose for the cooler.
