Rowdy burnouts and loud noises: The LSX/Subaru swap project
#302
Thank you sir! Yep any main load bearing points will get gussets. The pillars, rear section of the roof, the cowl, and the strut towers will all be gusseted to the cage.
#304
After grinding down the remaining protective coating, I spread the main hoop legs so I could slide the whole cage back.
![](http://uploads.tapatalk-cdn.com/20160825/59e05b778243bf175f789b87c28f7d93.jpg)
And then started back up with welding. I ended early tonight because of frustration. Took me a bit to get back into the groove but tomorrow is a new day.
![](http://uploads.tapatalk-cdn.com/20160825/a825968de31e78d18229c189d3e6f627.jpg)
![](http://uploads.tapatalk-cdn.com/20160825/6d8bb8b4477de80aa65d21fcb0c627bc.jpg)
![](http://uploads.tapatalk-cdn.com/20160825/1987fa985677eb83bb9feb659652de96.jpg)
#306
Made some serious head wind today. Two and a quarter junctions left and that will complete the door portion of the welding.
A few of my favorites from today.
![](http://uploads.tapatalk-cdn.com/20160826/f44854cc4de2f21c5188af76adc5c322.jpg)
![](http://uploads.tapatalk-cdn.com/20160826/b5fdfaf82023c214dbff87ae2fde7fb9.jpg)
![](http://uploads.tapatalk-cdn.com/20160826/7b3d601747215df7d34c0d43d5a6578b.jpg)
#308
So before I got started with the main hoop X I figured I better weld in the base plates while I can still move the cage around. For a mediocre mig welder I'm quite satisfied with how the fronts came out.
![](http://uploads.tapatalk-cdn.com/20160831/e308e8aedc851153c6b9f5b7f4bb38eb.jpg)
![](http://uploads.tapatalk-cdn.com/20160831/090be05097689827b890b7f2f19c407e.jpg)
Some close ups
![](http://uploads.tapatalk-cdn.com/20160831/c8506eb60c63e07d773301789ef6aa3e.jpg)
![](http://uploads.tapatalk-cdn.com/20160831/1ee94a75a88a22e914176bb991b59078.jpg)
Covered up the rear holes I dropped the cage through
![](http://uploads.tapatalk-cdn.com/20160831/d36b0b88db8f65e38080fa56e8b8f7d7.jpg)
And ended the night with tacking together my rear base plates.
![](http://uploads.tapatalk-cdn.com/20160831/bb315d25ca7ebe7ec21897f39004e797.jpg)
![](http://uploads.tapatalk-cdn.com/20160831/b6fd6dd7456d24d97a55123823caa09e.jpg)
Some close ups
#310
Got the rest of the main hoop X finished up. It seems to complete the cage. I'm pretty stoked to be on the downward part of the battle.
![](http://uploads.tapatalk-cdn.com/20160902/9f59c652ca5a237f3e46f3e7d38b1ed1.jpg)
![](http://uploads.tapatalk-cdn.com/20160902/7937ce913d2932d9186e7b280799b450.jpg)
![](http://uploads.tapatalk-cdn.com/20160902/8fed6ad9aec618b1a2deb0341347ac23.jpg)
Some minty gaps
![](http://uploads.tapatalk-cdn.com/20160902/6718b76a242263f00dc8fc02a95de8e8.jpg)
I can't resist a whole body shot when she rolls out of the garage.
Some minty gaps
![](http://uploads.tapatalk-cdn.com/20160902/6cd3d465be686a32005a68124853d0a7.jpg)
#313
#314
Welding the cage to the base plates was probably my least favorite thing so far. They're not my prettiest weld but I ran it rather hot and penetrated well. Next cage I'm moving the door bars about 2 inches higher to make this portion of welding easier.
![](http://uploads.tapatalk-cdn.com/20160904/074f1d435f7f457cbc1dc780b1eef501.jpg)
![](http://uploads.tapatalk-cdn.com/20160904/54cc52e2ea6080bec5751ae867d798c2.jpg)
#315
Tacked in base plates for the rear extending bars of the cage. They look small in the pictures but meet the 12 square inch requirement of the WRC handbook. I also took care of some would-be rust on the strut tower seams and C pillar seams.
![](http://uploads.tapatalk-cdn.com/20160907/f09cce393d0ffcbee420b96ea6c589ec.jpg)
![](http://uploads.tapatalk-cdn.com/20160907/5e5b56bfe003ef038ce83a4c8aa792b0.jpg)
![](http://uploads.tapatalk-cdn.com/20160907/932e68413b145d02c0b8c11bb1badab7.jpg)
![](http://uploads.tapatalk-cdn.com/20160907/2f678c5d0686a1cb6bad2265807f26e1.jpg)
#317
Finished up the two lower strut tower bars.
![](http://uploads.tapatalk-cdn.com/20160909/610bedd7863d23109a764cc798212a67.jpg)
The notches that meet the main hoop were particularly tricky to do.
![](http://uploads.tapatalk-cdn.com/20160909/73f613cabad6a2ec8e7e0fbcb236e399.jpg)
![](http://uploads.tapatalk-cdn.com/20160909/9cfac3a0698dbbab08903d9fafcca6de.jpg)
But it all came together well.
![](http://uploads.tapatalk-cdn.com/20160909/ddcb9f3fded30231f0c95997eff88fb4.jpg)
![](http://uploads.tapatalk-cdn.com/20160909/cfd35cb756acae244f8b5315474231b5.jpg)
I scooped my gusset material as well from a local supplier.
![](http://uploads.tapatalk-cdn.com/20160909/2f2c92bfd7e665a0e3888ee119e6912d.jpg)
#318
In order to weld the rear stays they had to be removed from the car. It was nice to weld something without mimicking a gymnast.
![](http://uploads.tapatalk-cdn.com/20160910/522db2782b9bbf2235df9ad4c85fb043.jpg)
While they were out it was much easier to weld the strut plates in.
![](http://uploads.tapatalk-cdn.com/20160910/2ebd49bd80ae58f349ead84ed2ea51a5.jpg)
![](http://uploads.tapatalk-cdn.com/20160910/f8a1344824db00dc046e6fa1774f5e4d.jpg)
And all tacked back in, ready to be welded.
![](http://uploads.tapatalk-cdn.com/20160910/74ee4b758eb1c14da63ac8f6d3bb46eb.jpg)
![](http://uploads.tapatalk-cdn.com/20160910/afd6d07796c87effb3a0e66acd216b93.jpg)
#320
