Rowdy burnouts and loud noises: The LSX/Subaru swap project
Introduction:
Hi, I,m Teddy! I'm 19 year old college student currently majoring in high performance motorsports at the University of Northwestern Ohio. I bought my first Subaru (my first car aswell) in 2010 and I've owned it ever since. The car has gone through a few different phases the most important being when I WRX swapped it senior year of highschool. If you want to check out the car's past looks check out my rs25.com journal here: http://www.rs25.com/forums/f145/t173...ly-driver.html which I keep up to date too.
A couple videos of when it was swapped and running. A quick highwway pull with a big turbo dart.
[youtube]nXklhecMTPE[/youtube]
And some parking lot fun. There wasn't nearly enough snow but still a good time.
[youtube]a0GVvXGYfAo[/youtube]
Enough about me, time to let you in on the car. I've always liked v8 cars. My dad has owned his fair share of built mustangs and the want for a v8 car rubbed off on me the more I worked on his car. Throughout highschool I didn't have the knowledge or time to take on such an extensive project (Don't let me fool you I still don't). I wasn't planning to start the project until I finished up school but the 205's oil pickup cracked and spun a bearing so that kind of jump-started the v8 shenanigans. Now that you've been caught up on what's been going on with the car i can fill you in on what the actual plans are for the car. I'm still working out the finer details of the build but the key concepts remain the same.
Current pictures of it:
Plans:
Want
Have
Engine / Performance:
5.3 Iron block LM7
Callies Crank
6.125" Diamond Rods
WiescoPistons
Ported 243/ls6 heads or afr 225s
Hi Ram style intake
Custom turbo manifolds
Borgwarner s496
Custom A/W cooler
Fuel:
Custom 20 gallon split tank fuel cell
Custom aluminum surge tank
Walbro 255 surge feed
Dual Bosch 044's for main feed
-10/12 AN feed
-8/10 AN return
Management:
Megasquirt V3
Custom Mil spec twisted harness with bulkhead connectors
Exterior / Aesthetics
Fiberglass front fenders
Rear overs
Custom sideskirts
M3 Evo adjustable carbon wing
V2 STI bugeye lip
Custom diffuser
Door molding/antenna delete
Scoop delete/hood vent
Interior Comfort/ Engine Monitoring
Gutted interior
Custom Tunnel
Fiberglass dash
Full containment aluminum buckets
Dash mounted tablet for gauge monitoring
Bluetooth accessories
Floor mounted pedal box
Suspension / Driveline
ISC N1 coils
ISC coil covers
06 STI hubs/knuckles
Brembos or big brake equivalent
2015 STI "quick" rack
IRS 8.8 rear diff
BW t56
DSS Axles
DSS driveshaft
DSS STI 05+ rear hubs
Custom Rear trailing arms and lateral links
Front subframe
Motor mounts
Transmission mount
Rear subframe
Miscellaneous
Full cage
Tube front
Shaved bay
Smokey burnouts
Pissed off Purists
Hopefully this weekend ill be moving the car from the storage unit into a more suitable garage. Ill have an update before the weekends up. Until then, enjoy!
The aftermath of the blown 205:
After dealing with multiple threats from campus "police" I had to move my car off campus. Apparently a non running car takes up a spot someone with a running car needs, because I don't pay to park to. AAA came and picked it up and brought it to my new "garage". I lifted the car two inches to get on the flat bed and still scraped the **** out of the rear bumper.
Its a single car 10x20 storage unit but has plenty of room to work.
Front body harness is labeled and removed.. I need to clean the garage before I pull the interior harness.
I also test fit the evo skirt. Looks way better than I thought it would. Just need to split it and make the mold for both sides.
Transmission and cross members are out
Front clip removed and I threw on a front wheel for the hell of it.
Plans:
Want
Have
5.3 Iron block LM7
Callies Crank
6.125" Diamond Rods
WiescoPistons
Hi Ram style intake
Borgwarner s496
Custom A/W cooler
Fuel:
-10/12 AN feed
-8/10 AN return
Management:
Megasquirt V3
Rear overs
Custom sideskirts
V2 STI bugeye lip
Custom diffuser
Gutted interior
Custom Tunnel
Fiberglass dash
ISC N1 coils
ISC coil covers
IRS 8.8 rear diff
BW t56
DSS Axles
DSS driveshaft
Front subframe
Motor mounts
Transmission mount
Rear subframe
Miscellaneous
Full cage
Tube front
Shaved bay
Smokey burnouts
Pissed off Purists
My neighbor is doing a doing an STi swap on a 2 door RS, pretty involved, but luckily most of his will bolt on. I've seen a few LS Subies, but always in for another. Good luck with build, and can't wait for the final results.
Picked up my truck from my parents house while I was on break from school.
Its 99' Ranger, 4x4, 5 speed 4.0, no rust. Picked it up for $1000 with bald tires and a bunch of Evap codes. Spent $50 on some barely used 31" mud terrains and $10 at the junkyard for a charcoal canister. In the sun it's almost BRP too.
Now that's everything is moved in ThatOneKid came over and everyone else and we stripped it bare.
