Rowdy burnouts and loud noises: The LSX/Subaru swap project
I've been asking myself the same question. I'm cutting the firewall a good bit to fit a t-56 so engine placement will be decently far back and hopefully low. I need to look at oil pans to see if I can get a front or a rear sump pan.
#34
(Basic performance upgrade package) 1,100.00
Billet keys 1-2, 3-4, 5-6
Bronze fork pads (1-6 and reverse)
Steel 3-4 shift fork
Compressed carbon blocking rings
Shim kit, Snap ring kit, Misc (sealant, cleaners)
1-2 synchronizer 145.00
5th gear 145.00
4th Gear (input shaft) 275.00
New bearings 200.00
Used main output shaft 200.00
theres whats done to it, its built with 0 miles, about 200 in work done, looking for 2400, its from a 99 F body, so its LS style and will mate to your motor
5th gear 145.00
New bearings 200.00
#36
5th gear 145.00
New bearings 200.00
5th gear 145.00
New bearings 200.00
#40
Damn, that going to be an epic project. I love Subarus, especially of that generation. I guess the swap will require conversion to RWD?
Just curious why are you using an iron block, Subarus already suffer from understeer due to the engine being so far forward? Why not go with LM4, L33, or LS1 aluminum blocks?
