Source for Good Fan Relay/Connector and other wiring supplies?
Old 03-23-2015, 05:08 PM
ssjimmyss's Avatar
Default Source for Good Fan Relay/Connector and other wiring supplies?
Thanks to some forum searching I think I have a pretty good idea on how to wire up my ls1 fans to be pcm controlled (98 LS1 Swap). However I am trying to find a source for the actual relay and connector/harness.
I have found some cheap relays/connector/wiring leads on ebay but the thickest gauge wiring I can find is 14. I was looking for 10 or 12 gauge based on what I have been reading, where would I find these? I want to avoid spending big bucks on the ready to go harness if I can do it myself.
For example...assume these are thin gauge wires:
http://r.ebay.com/h2Tc8j
Secondly I have an aftermarket EZ wiring harness and need to add some connectors inline so I can still remove the bed/front clip/doors without unwiring the entire truck. I have purchased some universal connectors from China that seem to work ok, however I think I need a special set of crimpers for the connector pins. Can someone point me in the right direction for a set of crimpers that will work with he little pins?
http://r.ebay.com/yvOycM
thanks
Old 03-23-2015, 05:57 PM
Project GatTagO's Avatar
Received 1,443 Likes on 911 Posts
I've used Waytek a lot, but you really need to know what you need.
http://www.waytekwire.com/products/
Andrew
Old 03-23-2015, 08:20 PM
76larkman's Avatar
I bought stuff on rockauto.com but shipping not cheap most of time on small stuff.
Old 03-23-2015, 08:23 PM
S10xGN's Avatar
Waytek is great, Del City, too...
Old 03-23-2015, 08:55 PM
Renegade6's Avatar
I've purchased from the first two but, not the last one.
http://www.wirebarn.com/
http://terminalsupplyco.com/default.aspx
http://www.wiringproducts.com/
Old 03-24-2015, 08:14 AM
Cyrus Johnson's Avatar
I use the GM WeatherPack connectors with good results. It is a little bulker but easy to service.
Old 03-24-2015, 12:40 PM
DW SD's Avatar
You can use a heavy duty relay like this for the fan, so you don't have to worry about the wimpy Bosch relay harness for the fan relay:
Amazon.com : PAC PAC-80 80-Amp Relay Battery Isolator : Vehicle Power Inverters : Electronics Amazon.com : PAC PAC-80 80-Amp Relay Battery Isolator : Vehicle Power Inverters : Electronics
I used this nifty fused relay box to move headlight / fan relay loads out of the cab of my truck and in to the front wheel well. It came pre-wired and loaded with fuses and relays for $100 or so.
http://offroadpassport.com/forum/showthread.php?t=1228
I used this junction box to make the connections to the harness connections to the front headlights, turn signals, relay outputs and triggers, etc.
http://www.delcity.net/store/search/...jsp?item=73800
And installed:
with mini relays and mini fuses and exposed junction box connections.
all buttoned up<br/>note, colored wires are 12V+ trigger (small) and relay output (large).
Old 03-24-2015, 01:14 PM
4LUX's Avatar
www.eficonnection.com
Old 03-26-2015, 12:39 PM
Pocket's Avatar
Those ebay relays do come with only 14ga cable. You can depin them and use basically any 1/4" push to seat tang terminal. A quick ebay search yielded this
http://www.ebay.com/itm/PER-074-20-Terminals-For-Relay-Connector-Housing-10-12-Gauge-Wire-Clip-In-Spades-/261376143437?hash=item3cdb3b704d&vxp=mtr
Underneath it was this gem
http://www.ebay.com/itm/GTCs-5-Wire-Relay-Female-Sockets-Terminals-x-5-sets-/191127680835?pt=LH_DefaultDomain_0&hash=item2c8018f743
Not sure what brand those connectors are, yakazi, deutche... doesnt really matter. They're crimp termination like nearly all terminals out there and go with 18-20ga cable
I use these. There are multiple tooth combos for sealed/unsealed, large and small terminals (ex 20ga GT150 terminals vs 12ga 630 terminals)
http://www.ebay.com/itm/Delphi-Weather-Pack-Metri-Pack-Easy-Crimp-Crimping-Tool-24-14-AWG-Made-in-USA-/271499784293?pt=Race_Car_Parts&hash=item3f36a5f065&vxp=mtr
Avoid these:
http://www.ebay.com/itm/Weather-Pack-Metri-pack-Crimper-For-Terminals-Seals-T-18-Weatherpack-Delphi-/361246451082?pt=LH_DefaultDomain_0&hash=item541bf7658a
Other crimpers exist, but that one should do all you need without breaking the bank
Old 03-26-2015, 01:55 PM
DW SD's Avatar
Pocket,
That is good info. thank you for sharing!
Do you have another crimper you'd recommend for other terminal ends - I use a lot of non-insulated terminal endss covering after crimping with adhesive lined shrink wrap.
I bought a (cheap ~ $30) ratcheting one from Amazon and found despite good reviews I didn't like it so much. It was good for insulated terminal ends (it came with 2 sets of dies).
Thank you!
Doug
Old 03-26-2015, 02:11 PM
Pocket's Avatar
Basic rule of thumb:
Open barrel terminal like the small ones above require a crimper for that range
Closed barrel terminals like common stuff you'll find anywhere (butt crimps included) can be crimped with nearly anything that clamps down. I prefer cast iron versions like this. The stamped tools tend to bend easily
Closed barrel terminals rarely produce a good crimp in one squeeze, so put a dab of solder in if you suspect the terminal may not hold. For that reason, I like to use the non insulated versions, solder and cover with my own shrink tubing after Im sure the termination is solid. FWIW, the only closed barrel terminal I use in harness building is for the starter solenoid because I simply cannot find an open barrel version. Mouser carries 8 and 10mm rings from delphi to match the OEM ground and power distribution and crimp nicely with any 630 capable tool
Quick Reply: Source for Good Fan Relay/Connector and other wiring supplies?
