foxbody ls 5.3 cam only 1/4 mile times?
Hey,im wondering what would a hatch run typically in the 1/4 with typical bolt ons like headers and a good cam.? Or what are your times n/a with a 5.3?
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
Oh ok,i was hoping high to mid 11,s.. i have all of the interior stripped, 3.27 gears, shorty sanderson headers from an s10 (nice fit) 706 heads. Ls6 intake built 350tr tranny,not sure on the stall unfortunately..
These look identical,im sry i didnt have a part number,however these or the only ones that look identical.im not sure about the stock k member,i know the passenger side will fit.im not sure about the driver side.id like to say yes because personally i think they would,however im not positive so i dont want to be a liar..
If you don't run 11s then something is wrong. On a tune only 2005 lq4 with flipped exhaust manifolds I ran 12.20 with a headwind and using a $279 USD (new) torque converter . My 1/8 mile of 7.72 converts to 12.05 in the 1/4 which possibly could have happened if wind wasn't an issue. These motors are amazing, I only paid $560 Canadian for mine with 100 000 miles
Nice u guys do anything new to the mustangs to drop the times down a bit for the new race season.. finally got mine running, gonna get the driveshaft cut and balanced tomorrow,so I guess we will see some times soon..
Did they actually let you run nines more than once without kicking you off the track?
the 1/8th mile track I run all the time and never teched. I actually have run numerous 6.0 passes there and never a problem. The 1/4 mile track I can run on test and tune and grudge days, but no events that are NHRA sanctioned.
Nice, the track I run at or kind of dicks, there quick to kick people off for running too fast.Nice notch by the way, very clean..
I have a chance to get this cam for a decent price do you think it'll work well in a 5.3
Lobe seperation 112.1
Duration 230/230
Valve lift 604/603
Duration 230/230
Valve lift 604/603
if the price is right then might be a good cam especially for a 5.3. I always run split pattern cams because of nitrous. Do yo have a good tuner, that cam will def need a good tune for it to run right.
Alright,I was hoping to hear that.I know a few shops that are pretty good at tuning cars.. I can get that cam for around 150$ so I'll probably buy that in the next few days.
Hey just wondering do you have your rpm /speedometer working? Ifso I was wondering how you did it.Thx
for the speedo I used Dakota digital. pricey but I wanted the stock look. tach, been now over 14 years, so I think the ecu harness has a signal wire I used. not sure how accurate it is but I let the trans shift itself.
my old 98 5.7 was cam only LS1 TSP 585 225, yank 3600 373 and DR's went 11:60's all day long. that combo lasted over 10 years, put on ported 799 CNC heads, Fast 98 and Fast 98 t body and it dropped to 10:90's. Still have all the parts to that motor, that was one of the best street able combo's I had, on the highway it got about 24-26 mpgs.
thx I'll have to look into that, I'd like to use my stock gauges.Found out my rear end has ford racing 4:10 gears.that should bring the quarter mile times down a little.(even though it sucks for highway driving)
