530ZX - In progress
Old Jan 20, 2016 | 10:07 PM
blackened's Avatar
Removed the factory sound deadening with dry ice, a deadblow, and a chisel
Found some more cancer on the drivers side. Below is by the rear seat mount and there is also a small spot (not pictured) under the gas pedal. This is good, because i extremely dislike welding sheet metal
Old Jan 21, 2016 | 06:55 AM
Pop N Wood's Avatar
Ahh. Dry ice, a dead blow and an old Z car interior. Memories! That is definitely the best way to get the factory stuff out. I think whatever tar stuff they used is what gives Z cars their unique interior smell.
I like that wrinkle finish you put on the motor. Should look good.
By the way, I burned my bushings out as well the first time I did some, but later used a hole saw. Much cleaner with the hole saw.
Old Jan 21, 2016 | 08:40 AM
Nismo Kid's Avatar
I must say this is one of my favorite builds. It's nice to see another Z31 join the mix here on tech. Keep up the good work
Old Jan 21, 2016 | 09:21 PM
blackened's Avatar
Thanks for the advice!
Thanks sir!
Old Jan 22, 2016 | 01:36 PM
lowlyfe_taz's Avatar
This thing is coming together amazingly. Your attention to detail is amazing. I cant wait to see more on this. The wrinkle finish is super sick BTW
Old Jan 22, 2016 | 03:22 PM
Project GatTagO's Avatar
I like what you're doing. Good attention to detail. You might have gotten some tips from my Cougar build :-)
Keep up the good work.
Andrew
Old Jan 22, 2016 | 03:33 PM
AAIIIC's Avatar
Excellent work, and excellent job on all the photo documentation. Interested to see more as the project continues!
Old Jan 22, 2016 | 06:57 PM
DW SD's Avatar
Cool car and project. I had a V8 powered 240Z I built in my first engine swap some 20 years ago. At the time, it was the quickest car I had ever driven.
Enjoy this!
I noticed your heavy gauge wires passing through the firewall without a grommet to insulate. I'm assuming you just hadn't installed yet. If not, the sheet metal as the car vibrates, will cut through the insulation on the 12V+ and arc potentially causing a fire. Please don't overlook that.
Doug
Old Jan 22, 2016 | 08:47 PM
jmilz28's Avatar
Good work! Looks like you're paying attention to the details that will make this thing reliable like factory. Awesome build and thanks for the pics and details!
Old Jan 24, 2016 | 12:06 PM
Red89GTA's Avatar
very nice work and build thread can't wait to see the finished product.
Old Jan 24, 2016 | 03:19 PM
Area 51 Racing's Avatar
Soo this is what patience looks like.... Nice bro. I'm a Z owner as well, 370 Nismo. Keep the updates coming
Old Jan 25, 2016 | 07:42 AM
  #32
blackened's Avatar
Thanks! I really liked how the wrinkle finish came out too
Andrew
Thanks! I'll check it out
Thanks! Hopefully the pics will help someone
Enjoy this!
Doug
Thanks! I'm really looking forward to it being done, and yeah i just haven't got the grommets in yet
Thanks! I'm trying to get as much documented that makes sense
Thanks!
Thanks! Those nismos are sick
Old Jan 25, 2016 | 08:08 AM
  #33
blackened's Avatar
Cut out the rust and welded in the new panels
Old Jan 26, 2016 | 12:36 PM
  #34
FrossB's Avatar
During the start of your engine tear down pictures and repainting of the engine, I was questioning whether I was in my build thread or not haha
Check out the first couple pages of mine and you will see why!
Nice start on the build btw!
Old Jan 26, 2016 | 07:42 PM
  #35
blackened's Avatar
Wrinkle black ftw! i thought about using that gold but i really was liking the copper. Thanks man!
Old Jan 27, 2016 | 01:23 PM
  #36
FlatBlack's Avatar
This is a super cool build - you spent waaay more time on your LM7 than I did mine, looks fantastic!!
Loving the C6Z too
Old Jan 27, 2016 | 07:24 PM
  #37
Jay Gadsby's Avatar
Just noticed the Holley Fuel rails. I will be using them as well, thanks for all the pics and motivation.
Old Jan 27, 2016 | 09:34 PM
  #38
blackened's Avatar
Loving the C6Z too
Thanks man! I'm planning on running a S14 rear sub frame to benefit from the improved anti-squat over the S13 and also to maintain the 5 lug hubs, but really wanted to run the Z32TT diff/axles because of the thicker axles and larger diff. So how much did you have to mod the sub frame to fit it in the S13 sub frame?
Thanks man, i'm glad it helps! I got the rail kit off of a site named after a large river, and in fact, i got a very large number of parts off of that river site
Old Jan 28, 2016 | 09:44 AM
  #39
FrossB's Avatar
The Nile ftw!!!!
Old Jan 28, 2016 | 01:20 PM
  #40
Forcefed86's Avatar
Careful with the F-body pan and high volume oil pumps. Mine would uncover the pickup under hard acceleration. Went with an improved racing baffle kit for the F-body pan to fix it.
