Hooker 1964-67 A-body LS swap system preview thread
#261
The brackets depicted in post #87 are merely the mock-up parts that I used to establish the critical geometry that both the forward-bias and rear-bias brackets were designed from.
#268
Hey Todd,
Got my headers last week and they fit perfect, even with my home made motor mounts. I am considering ceramic coating the headers and wonder if there is any reason not to? Will it compromise the headers in any way? Also, along with the motor mounts hooker makes do you have any plans for trans mounts? I am installing a TR-6060 and have not found anything but the factory style mounts. As I am using poly motor mounts I would like to use a poly trans mount. Any help would be great. Thanks, Brian
#269
Hey Todd,
your transmission.
#270
#271
Thanks Todd,
After I wrote the post this morning I went out to the shop and cut up the factory mount and as you suggest I modified it to use the energy suspension poly mount. Again great job on the headers! Do you know when the exhaust system will be available and do you have part numbers.
Thanks again for the great work, Brian
#273
Thanks Todd,
#274
Brian, the part number for the 2.5" exhaust system is 705013110RHKR and the 3" system is part number 705013111RHKR. There are 5 of the 3" systems existing in Holley's inventory, but the 2.5" systems have not been ran for the first time yet.
#275
Hanks again Todd,
As for the crossmember, I am currently using the stock one that I have modified to work with my boxed frame. Not sure it will give me the clearance I need between the floor and exhaust pipes. The header collectors are about 3/4 of an inch from the floor pan right now. Which brings up another question, what is the best angle for the motor front to back if the chassis is level? You may have already touched on this in the thread. I would like to get the bottom of the trans level to the frame rails side to side for ground clearance but that may push the nose of the motor to low.
Thanks, Brian
Thanks, Brian
#276
Hanks again Todd,
Thanks, Brian
Thanks, Brian
#277
That's what I thought about the drivetrain angle but always better to get second opinion. Looking back in the thread to post 197 you show the prototype crossmember and its mounts. It looks like the mounting brackets move the crossmember bolt points inboard of the frame. Could I fab up my own brackets to make this work with my boxed frame without cutting down the crossmember?
#278
