Question about VSS
Dakota Digital makes a pass thru VSS for manual speedo output. It will signal the speed to the ecu to cure stalling issues, but does not provide a high enough pulse rate for smooth DBW cruise control.
For that, I added an aftermarket VSS to a T10 trans using the reverse gear as a reluctor.
http://www.dakotadigital.com/index.c...prod/prd57.htm
However the low pulse rate results in inconsistent speed readings so the DBW cruise control over reacts with nearly wide open throttle then directly to idle while trying to maintain speed.
Your comment about altering the ECU via tune to accept a different count VSS is interesting. Dakota makes an 4000-8000 pulse per mile cruise unit (designed to accept a magnet on the driveshaft) that works with the factory DBW set up. Wondering if I could also use that signal to provide the ECU what it wants. Sounds like your experience was positive on that front....
Which ECU are you using?
I've also got an 05 truck ecu I'm using with aftermarket VSS and cruise.
Jags that run sells a bolt on reluctor that fits the yoke of the diff and a standard GM reluctor that bolts to a diff mounted bracket (no movement). It's for an S10 IIRC, but would be easy to duplicate.
As for the VSS, any 2 wire (sine wave) VSS can work for the ecu. However, there's a minimum amplitude required. That will be determined by the VSS, distance to reluctor, and reluctor speed. On my 05, aftermarket VSS, a distance of 0.02" was required.
So, the pickup for my old Rostra cruise on the Ford V8 is a "2 wire" that senses a magnet on the driveshaft moving by the sensor. Is that generating a 'sine wave' output? I was under the impression that when the magnet is in the sensor and the iron-tooth is moving (as in the LS case) that it's generating a square wave output, not a sine wave output. Am I mistaken in that?
The GM 2 wire uses a mag in the sensor and detects the metal reluctor going by. Check out the Jags That Run setup.
A 411 is the ecu used in 99-02 f body, corvettes, and trucks.
Andrew
50 mph in 6th, press the clutch, and a long coast to a stop on off ramps.
Andrew
If you want subtle drivability issues, a high idle masking them, and no gains whatsoever, delete the VSS. The same vehicle with the VSS will drive better. It's been that way since the early 80s. Sure, it's easy to find fellowship in the "doesn't matter" club. But transitional changes in engine management parameters are helped by having a VSS.
Nevertheless, eliminating the VSS in this application is exactly the OPPOSITE of what I want to do Matthew. I'd like to come as close as possible to giving the ECU exactly the type of signal it gets in the factory application. It's simply that doing that outside of the tranny is proving to be challenging. For me anyway. But, perseverance will get me there. We're gonna try to rig up the yoke on a drill and use an oscilloscope and the factory sensor to see if what we've got will work. And then adjust accordingly.
Appreciate all the help guys.
I just added a VSS to my 10 using the 39 tooth reverse gear as a reluctor.
See post 25 in this thread. BTW, it was an aftermarket VSS, so that may explain the need for the narrow 0.020 gap.
https://ls1tech.com/forums/conversio...-ls-motor.html
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
