G body ls1 swap questions
Old 04-14-2016, 12:49 PM
G-Body love's Avatar
Default G body ls1 swap questions
I need help I'm wanting to do an ls1 and t56 swap in a 85 Monte I just need a list of what to do basically. The wiring has gotten me confused I want a clean wiring set up and budget is not a problem right now just need some help any info could help.
Old 04-14-2016, 01:08 PM
1964SS's Avatar
If you get the harness with the LS1 they are pretty easy to strip down into a stand alone harness. http://lt1swap.com/ has all the pinout information you will need.
If your worried about doing the harness yourself then there are several vendors that will modify a harness or make a new stand alone harness for you. Here are a few vendors you can contact about the engine harness.
http://www.bp-automotive.com/
http://www.speartech.com/
https://www.psiconversion.com/
Your PCM will need to have the vats tuned out of it as well for a stand alone system.
Old 04-14-2016, 01:19 PM
Okay thank you another thing is how would I tie the ls1harness into my stock gauges and all that stuff in the interior because I noticed when I took all the inside wiring out the computer had wires going up into the dash
Old 04-14-2016, 07:35 PM
spacemanspif's Avatar
You'd need to keep your stock sensor wiring and sensors and adapt them to fit the new engine. You'll need a converter box to run the mechanical speedo and I'm not sure of the stock tach will work.
Old 04-14-2016, 07:46 PM
1964SS's Avatar
I think 85 has an electronic speedo, but not sure.
Old 04-14-2016, 07:55 PM
Whoever had the car before me ran a 355 sbc and cut all the engine wires off and the wiring is rigged the only wires coming from the computer were going into my dash
Old 04-14-2016, 08:03 PM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
https://ls1tech.com/forums/conversio...ap-thread.html
https://ls1tech.com/forums/conversio...m-preview.html
Old 04-15-2016, 08:37 AM
Gauge wires run from the driver's side bulkhead. Stock computer stuff came out the passenger side of the firewall.
I should clarify my last statement a bit: if you are running a new trans like 4l60e you'll need the converter box for the speedo. If you are using a th400, 200r4 or other trans with a speedo cable drive, then the stock speedo will work.
Quick Reply: G body ls1 swap questions
