I discovered the original Ford line bolts in to the 5.3 power steering pump but, I don't know if it will leak the tip end is different. Any info greatly appreciated. The Ford line is the 1 on the left, the 1 on the right is the original 5.3 line out of a Suburban.
Im guessing it wont work, but that style of ford fitting will swivle even when tight, so not sure if it has to bottom out in anything. But heck, why not just try it, all you'll be out is a little fluid if it doesn't work. There is usually a nylon ring that seals it at the threads, do you have that? Post back if you try it!
