A few basic questions for you pros out there
Quick question. This is my combo on an LS swap into a 66 Chevy C10 so far:
2004 Corvette LS1
243 Heads
BTR Stage 4 \Truck cam
1-7/8" long tubes
FAST LSX 92 intake
FAST anodized fuel rails
Corvette regulator
Ported LS2 Throttle body
Will 36lb injectors work well or should I run 42lb? And with that combo, I need EV1 style LS1 injectors, correct? or do I need an LS2 style?
Is running a MAF better with a 411PCM and drive-by-wire setup? I need to order a custom harness and need to get these details sorted.
2004 Corvette LS1
243 Heads
1-7/8" long tubes
FAST LSX 92 intake
Corvette regulator
Personally I've had great results using the MAF and 411 pcm.
Also stock 02+ ls1 injectors should be sufficient for that power level. Not sure what style injectors the FAST 92 uses, a quick search on here should find it.
Restricted User
Might as well go with the larger injectors. Get them with a connector to fit your harness. No reason to change injector style.
Will a 411 PCM control drive by wire?
The 36s or 42s will work absolutely fine for your setup. Whatever injectors you purchase just make sure you have the harness built to match. Whether you run the MAF or not is up to you and what your tuner prefers. I personally see no reason to not run one in your application though.
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic302845_6.gif)
Aaron @ Scoggin Dickey Parts Center
Email:Aaron387@sdparts.com
Phone: 1-800-456-0211 Ext: 324
Whether to use or not use a MAF is (as I understand it) somewhat dependent on your circumstances:
If you live somewhere like Florida, Texas, or Kansas, where there's not much chance of significant changes in altitude, then a SD tune is easier to justify (& live with).
Significant changes in temp/humidity/altitude/etc. will test the capabilities of a SD tune, & MAF-equipped vehicles will generally have a real advantage in those conditions.
I live in the Rockies, so a MAF sensor is virtually a requirement for my car - but I can see how people in other parts of the world might do fine without one.
I agree 110%. Think of it this way -
A speed-density (IOW, MAF-less) tune is using a bunch of pre-determined values for any given load, throttle-postition, etc. If you have a good tuner, & your environmental conditions don't change too much, the vehicle will generally run pretty well - but all of the values being used are a "best guess".
When a MAF is being used, then the spark/fuel/timing tables are adjusted based on actual, measured values of atmospheric conditions at that location/time. And if you drive from somewhere along the PCH on the California coast (maybe 83* F & 70% humidity) to Las Vegas (maybe 101* f, & 8% humidity), the MAF-equipped vehicle won't miss a beat.
(I briefly considered using a more-extreme local "mountains-to-plains" example, but that might not represent what most people experience...)
My previous answer was a little bit incomplete, so I thought I'd add the last little bit here -
There are quite a few injector-size calculators on the 'net these days, I used this one to throw a few numbers together as a "wild-@$$-guess":
I guessed that your engine might make 380 hp, it might make more or less, but I feel that's a decent "ballpark" estimate. Given that, & a relatively-normal BFSC & an 80% max injector duty cycle, this calculator suggested injectors with a flow rate of 29.69 lbs/hr. The 36 lb./hr injectors you mentioned should work nicely, & even give you a bit of room to grow.
Good luck!
Good luck!
My first LS1 car was making 540fwhp confirmed at the drag strip MPH and weight of my car. Stock 99 LS1 injectors. The tune was also on the rich side, had more in it but our local track closed soon afterwards.
I prefer maf sensor for vehicles under 450rwhp
much faster to tune, easier to tune, done in couple hours or less.
MAP tunes are much more personal and require you to drive the vehicle through the range of conditions (bunch of cold starts and cold driving, night time day time, electrical loads and so forth)
Only really great thing about a MAP is you can delete the MAF. So that is why it helps on higher power cars: You dont want that thing in the air path.
