Need advice on a frame for my ls1
I'm contemplating just selling my frame for scrap and trying to find a different donor vehicle, maybe not even a fiero, but something else that's lightweight, like an old porche 944, or a dodge daytona (are those rear-wheel drive? it'd be fun to try to get that piddly turbo on my LS1), perhaps a 300Zx, thought of doing a civic conversion and taking the driveshaft and differential from a TA and bolting it to a gutted frame, or maybe even a fox-body conversion since I can find the 4banger editions for about $1100. changing frames screws with my budget a lot, but if need be I can wait 4-5 more months to save up for a different frame.
any suggestions on what I should do? from the way the crack looks, I think someone dropped the tranny on the ground at some point in time and I wouldn't want to risk using the tranny if it were possible to rebuild it.
small block...and racing at the track. Shoot me an e-mail and I'll ask him
if he can get his hands on one for you. Later...
www.fiero.com
http://www.fiero.nl/cgi-bin/fiero/Ul...i?action=intro
those are the only two I found that are remotely active.
later
tim
later
tim
I'll look into this ASAP. Trending Topics
A daytona is FWD, so I'd scrap that. 944s make excellent Ls1 candidates. 300Zx will have differential problems with anything above a stock motor unless you use a 90-97 model, and those are still fairly pricey. Fox bodies are a superb swap candidate, and they are available for as little as $500 if you do a little digging.
The fiero wieght is around 2650 stock, that's the base 4 cylinders. I don't kow how much they go up from that.
It will probably require alot of mods but a car that is very light that you wouldn't expect are saturns. I had a 98 SC2 it was around 2550. that's a decent size car. And the older ones. like my 92 SC2 wieght just under 2400 lbs. Now that's getting light. And I know its light, the motors only make 123hp and I put it down on some Z24's civcs and some others. Yeah yeah civic racing.
Good luck with the project.
you can buy my 92 if ya want
