LS3.430-> Temp and Oil Warn settings?
What do you recommend setting the warning at? I know that LS engines today run hotter than the old 350s I used to run.
I'm controlling them from the temp unit in the front of the left head, which is wired into the PCM harness. I'll have to investigate what temperature that is set.
Thanks for that thought process. It makes sense.
I'd want a warning if it was getting above 220, even though I would not be concerned unless it started climbing. So if I had a warning at 220, then I can start to see what was going on more closely.
My Cougar rarely gets above 205 on the stock thermostat and I think I have a warning set in my Holley dash at 220...
Andrew
FWIW, I'm using the ground provided by the ECU to activate the first fan on mine (on at 226F) to turn on one of my un-used idiot lights as a warning, much as you are. My t'stat is stock (new crate LS3) and began to open at 186F - fully open by 188F. With enough airflow across the rad under cruise (winter anything above 20 mph or so, summer 35mph) the sender for the ECU head temp sits right at 195F-196F in mine. I have my variable speed fan controller set at 202F and when the fans are on, I'm seeing 199F-200F head temp pretty consistently. Hopefully, I'll never see my warning light come on.
Sounds like your setup works very much like my Cougar. When moving, the fan barely comes on. I am using PWM to control the fan speed. I was driving it today and it got to 200 and fan speed got to a max of 20% and the temps started to drop. This was in stop and go traffic...
I ramp the fan speed pretty aggressively above 210, but I never get there under normal driving conditions. Having a hole in the hood helps a lot!
Andrew
That's good stuff there!!!
There is a way to implement PWM control with your stock ECU. Also, as I understand it, you can install a AC pressure sensor (0-5v) and have full control of the fans with a table that is engine temp vs. AC pressure. This will give you the optimal control. The speed will take care of itself...
Here is the thread:
http://www.lateral-g.net/forums/showthread.php4?t=40215
It is long but has a ton of useful information, should you go that way.
Andrew
