Gen 4 rotating assembly in gen 3 engine
I've got a friend who accidentally order a 58x dragon slayer crank for a build in a gen 3 engine and had to use the lingenfelted converter box. It's been a nightmare with startup problems. I don't want that mess.
We've been trying to brain storming ways around it with using an e38 computer and changing the throttle body to drive by wire.
Question: is it possible to use a gen 4 timing gear, cover, and sensor on the gen 3 block? And possibly drilling the side of the block for new style knock sensors, then using a gen 4 harness into the e38 pcm? I know it's a lot of hassle but not as much hassle as we've had with that converter box.
I know the cover, cam gear, and sensors need relocated, but as far as the crank goes, could it be as simple as dropping in a new GEN 4 crank with the right wheel?
