Vortec 5.7 in Mercedes W140
I have a Mercedes W140 with a non-working motor and a Chevy Suburban 5.7 1998 with a powertrain in quite workable condition. Did anyone swap like this (GM V8 in Mercedes W140) in the forum? Is it true, what the engine is getting into its native mounts without redoing the steering system? What exactly should the oil pan be used for, does the standard of the GTO fit? Is it necessary to weld a drive shaft or are there ready variants?
In the search found Mercedes 400S with LS6, but in the text did not find unambiguous answers to their questions.
Thank you all.
Thank you all.
I think that part of the difficulty you will encounter is that many people on this board are not familiar with what a "W140" Mercedes is. (I don't recognize it anyway.) If you were to post a picture or three, it may help people to relate it to something they're familiar with. Good luck.
Thank You for information. Does that mean I can use oil pen from old car models like Chevrolet Corvette with SBC (LT1)?
Benz of that era (most eras) have a big recirculating ball steering box and related more complex/cumbersome steering linkage. This does indeed seem to cause a number of challenges with swaps. Many fabricate a switch to rack and pinion steering. This guy added a whole new front clip/suspension with rack to create the room on the bottom. Slightly different era -- but similar problems.
http://www.streetmusclemag.com/featu...ed-benz-vette/
Understand -- and as I mentioned, I realize the body style is not the same. But I've seen articles on a variety of Benz models - the steering box/linkage interference always seems to be an issue with V8 swaps. Not sure the additional room under the hood is going to remedy the challenge low in the engine bay. In any event -- not a lot of these out there. You're likely going to have to just dive in and then solve the problems as you come to them.
