Dirty Dingo slide without hoist?
Old Mar 22, 2018 | 07:47 PM
Mr.Bu's Avatar
Default Dirty Dingo slide without hoist?
Was curious if I could slide my engine/trans back on the dirty dingo sliders without a hoist?
Old Mar 22, 2018 | 09:11 PM
H20cooled's Avatar
I have never been able to especially with the tranny attached.
Old Mar 23, 2018 | 02:51 AM
tfi racing's Avatar
With the correct length pry bar,suitable fulcrum and enough force, moving almost anything is possible...
Old Mar 23, 2018 | 03:51 AM
85LSXTRUCK's Avatar
You can in many ways. The way I done it was with a come along, was easy.
Old Mar 23, 2018 | 01:01 PM
Floader's Avatar
Floor jack on the oil pan to take some of the weight off worked for me.
Old Mar 23, 2018 | 02:24 PM
HighLiner's Avatar
Since this is a Dirty Dingo thread might I ask since the motor mount thru bolt is also slotted up and down. What is the best way to center the mounts?
Old Mar 23, 2018 | 07:13 PM
IAGXP's Avatar
I put the floor jack under the trans to remove some weight, then grabbed the tail end of the trans and moved it back and forth while pulling. It moved much easier than I thought.
Old Mar 25, 2018 | 04:21 AM
Romulus22's Avatar
are you saying if I had a long enough stick I could move the earth?
Old Mar 25, 2018 | 10:46 AM
Absolutely!! lol
Old Mar 25, 2018 | 01:42 PM
Michael Yount's Avatar
...don’t forget suitable fulcrum...which in space, is hard to come by.
Old Mar 25, 2018 | 03:59 PM
Mr.Bu's Avatar
If anyone’s comes across this in the future , I moved mine today really easy. Loosened bolts on the dd’s, loosened trans mount bolts and jacked up the front of the trans pan. Was able to push the motor back really easy. Just needed clearance between my pan and crossmember.
