Oil pan suggestion
How about the vette pan? Don't know much about the Holley pans, they were not out when I swapped pans.
https://ls1tech.com/forums/conversio...o-ls-swap.html
edit: the fbody pan will need to have pickup tube lengthened as well as the pan notched ( not sure if you were aware of that). It may be cheaper and easier to buy Holley pan and sell the fbody one.
Looks like no clearance issues at firewall..best of luck to you!
Leon
To clarify - I went with Mast because it allowed me to mount the engine significantly lower than the Holley 302-1. At that time, they hadn't come out with the 302-3 yet which also allows for an even lower mounting of the engine.
