Don’t know much about LS1
The truck has been rough idling and running like crap lately.
Z06 cam
what we have changed.
Maf
map fixed an issue where it would bog out while driving.
O2
tps
plugs and wife’s
crank sensor
Random misfire code.
Truck will idle ok sometimes but most of the time really rough. Same with driving. It will run fine and then after a stop or turn on and off runs like junk again
ive read a lot of threads here all with different fixes. Most of which I changed.
Any ideas?
A bad tune makes the problem repeat itself at the exact same situations over and over again. There is always a pattern to be found when it comes to software.
When it runs fine, try to make it run bad again by twisting and bending all electrical connectors and wires.
