With the Gen 5 ECM, is a neutral safety switch
Is a neutral safety switch required or does the ECM communicate with the TCM to determine if the transmission is in Park or Neutral?
I received my harness and ECM back from SwapTime for my conversion and there doesn't seem to be a place to connect the neutral safety switch. I suppose I could still run the Ignition wire through the neutral switch anyway, but is it really needed?
Also, the conversion is going into my 1982 Toyota 4x4. When I shift the transfer case into low (I actually have two low gears), how will the ECM know its in Low?
Any help would be appreciated.
Bryan
Getting pretty close to starting this thing
This guy is very busy and he rarely has a chance to reply to my texts or emails. He instructed me to call him rather than message him because hes very far behind on answering questions. Not the best thing for a business but at least he was honest about it lol.
ECM and TCM talk to each other to to tell what gear its in but I do not believe there is a direct output signal or signal you can use thats not CAN to incorporate the switch. His module converts the CAN signals to a more traditional signal I think.
