installing 2020 Corvette engine and DCT 8 speed transmission in 2007 LS2 Corvette
can LT2 engine and DCT 8 speed automatic transmission of the 2020 Corvette be installed in my 2007 LS2 C6 Corvette
Do they fit in the 2007 C6 Corvette, specially the 8 speed DCT automatic transmission?
Thanks for help.
Thanks for help.
The following users liked this post:
Long Beach GTO (08-12-2019)
If you mean the new 2020 mid engine Vette, then no, it won't fit. A mid engine drivetrain can't fit in a front engine rear tranny car. I don't know how you think it would.
both LT2 engine and the DCT 8 speed tranny of the 2020 C8 Corvette might be provided from the factory in 2021 camaro so the LT2 engine and DCT tranny might fit in a 2007 Corvette, maybe the engine wiring harnesses of the 2007 Corvette and maybe 2021 camaro can be merged and tweaked to work in 2007 Corvette.
As usual, details matter. Most people refer to your C6 Corvette as having a “transaxle”. It doesn’t. It has a version of Tremec’s 6 speed bolted directly to the rear diff housing. If the new mid-engined Vette’s DCT is part of a true transaxle, then fitting it to your Vette OR to the 2021 Camaro falls into the category of “you can MAKE anything work - time/money”. If it’s configured like the current Vette (separate tranny/diff) it can probably be more easily refitted to other vehicles.
Clarified today - the new midengined Vette has a true transaxle. The bulk of the transmission/rearend combined unit sits BEHIND the rear axle. So fitting it to a front engined car is a no-go. However, remove the driveline and backseat from a Prius, and after some surgery, LT2 midengined Toyota w/8spd DCT is possible. 😎
