LQ4 + E90 should = Love ? build
. Rules, must stay as BMW on the outside as possible, do nasty V8 burnouts, run "smooth", annnddddd automatic ( promised the wife this one would be "her" friendly). So lets the games begin. The build be be done at a hope full steady pace with $$, shipping to Canada and being a father at hand.. Ive always liked the BMW styling and yes they do make a stout engine buuutttt well not so much for this one that is running poorly. The install is pretty simple, gonna be running the stock gm ecm which will control the fans, fuel pump and AC ( last project).issue 1- this chassis run a dead head fuel system at almost 75psi ( teste don a gauge).. custom set up with a corvette return reg/filter combo or clean fuel cell in the trunk?
issue 2- gauges, though bmw do make a very clean, simple and attractive gauges, i can get them to work im pretty confident but i will have a xmas tree of warning lights, or clean "autometer" style cluster.????
These are my first issues off the top of my head. If anyone is interested in the build please im open to opinions to these two
Engine tear down begins tomorrow!
6.0 lq4
Mr.blue
The idea of changing the fuel pump "design" in the BMW would be quite the task being they run a two sump tank which accommodates for the driveshaft running down the center.. this consists of drivers side an internal frpr / jet pump that with the return has hoses that go to the other sump to maintain equal fuel level.. the other side consists of the standard In tank fuel pump setup that sends fuel though a hose to the frpr ... Here's a pic 😊.
As for the stock BMW fuel pump flows 350lbs/hr which is approx 250lph. At 72 psi.. which is almost compared to a walbro gss342... I'm going to try this fuel pump but I will monitor fuel pressures...
As for the 70-72 psi, can the ifr tables in hp tuners be adjusted for the increase in pressure to run properly?
So the engine is torn down to it's bare long block.. some serious **** went down with the fan hub.. option A goto work to get the write tool on my holidays.. hmmm or option B I'm not gonna need and and am gonna replace the water pump anyways...
Well the engine will be pulled Saturday in the BMW at a friend's shop where it is..then next week the install should commence
