LS3 PCV / Catch Can Routing for Holley Valve Covers and LS3 Vented PCV Valley Cover?
Hey all, I have a 416 LS3 in a 77 C10 pickup using Holley valve covers and a C6 vette (manual trans) vented valley cover, and L92 truck intake.
How would y'all route the PCV setup? I've welded a 3/8" barb to the intake tube, which currently runs to the passenger side valve cover. For the dirty side, I have two options:
Driver's side rear port to intake (or through catch can)
Valley cover to intake (or through catch can)
You have to be aware of one thing (ask me how I know.... LOL)…… The GM valve covers have restricted passages (.115 dia) in the hose connection ports...…This restricts the amount of vacuum that is allowed to suck the oil vapors out of the crankcase...…. The aftermarket valve covers don't have these......When I did mine not understanding what was happening with the extra vacuum..... It ended up that very shortly after driving the car it started smoking like crazy...… Hummm!!!...… I checked the catch can and it was full to the top with oil which was sucked into the intake and burnt...…. what I did to resolve the issue was to make a inline restrictor with a .115 dia hole in it to control the amount of vacuum allowed to suck the vapors...…. I put it in the feed line from the catch can to the intake port connection...… Problem gone...…
Ken
Ken
The following users liked this post:
G Atsma (05-25-2020)
Ken
Ken
Ken
Ken
I took a aluminum round and turned hose barbs on both ends and drilled the restriction hole thru it...…
https://www.summitracing.com/parts/b...SABEgLNbvD_BwE
If Holley recommends that part I would use it...…… They are the best !!!!… I didn't know about that when I did mine...… Maybe if I would read the instructions...…..LOL...
