I have a 2007 Escalade L92 in a 1951 ****** pickup. Been running around 5years. A few months ago it got really hard to start. Replaced fuel pump but did not help. I have good fuel pressure but have discovered that the injectors aren’t firing using a noid light. By cranking for a while the injectors will finally start working. Any ideas where to start? Nothing shows up on scanner. ECM was programmed by Speartech.
Speartech modified the harness originally and it ran great. It started doing this a few months ago and seems to be getting worse. No other harness mods done since. Thanks
Sounds like deteriorating connection(s) He needs to check ALL connections and existing grounds. Adding grounds is not the cure. All existing ones need to be good.
Thanks guys for all the help. Checked all grounds and all were good. Turns out that it was the battery! It cranked over very well but voltage was dropping to the point that it wasn’t firing the injectors! New battery and all is well. Thanks again.
Turns out it was a bad battery! It cranked fine but voltage drop prevented firing injectors. Replaced battery and everything is great. Thanks to all who chimed in.
