View Poll Results: Is it a good idea to purchase a Holley Terminator X system used?
Voters: 9. You may not vote on this poll
Buying Holley Terminator X Used?
I'm currently researching and gathering parts to LS swap my 1993 Caprice wagon. In the course of doing so, I've found more than one instance of Holley Terminator X systems being listed on local classifieds (such as Marketplace) for what appears to be a good $1000).
I know there are a lot of caveats that have to be included in this conversation (can I see the item in person and pay in cash? Is the item real? etc...), but assuming all of these things are true, here's my question.
Is there a way to check a Terminator X system to ensure I'm not buying a paperweight if I'm buying used?
Thanks in advance for your help!
I wonder if Holley has a service to "go through" used ECM's of their mfr?
The following users liked this post:
transam7801 (12-18-2022)
You can also see if the seller will make a video of the unit being powered up and have him do things with the 3.5" handheld. Maybe running through the Wizard to load an initial tune.
Andrew
The following 2 users liked this post by Project GatTagO:
Pro Stock John (12-18-2022), transam7801 (12-19-2022)
Is it used as installed and removed? or used as in purchased and removed from original packaging and not run on the car? There are a lot of people that start a project and change direction. Just need to be able to jump on it when it happens. I am a fan of buying stuff and saving where you can. but you run the risk of buying the same pieces a few times. And a lot of waiting. I'm learning with this build to just save and buy new.
I do Holley remote tuning and I use TeamViewer software for remote access. If the seller is willing to connect power to the ECU and connect the tuning cable to a computer, you can log in remotely and check if the ECU will communicate with the laptop. If it does, chances are it is in good shape.
Andrew
Andrew
For instance, If I had a car battery, would it be possible to do a temporary hookup to check function?
