iBooster vs Hydroboost - detail overview, dimensions and functionality
Old 01-25-2023 | 04:45 PM
  #41
Project GatTagO's Avatar
Originally Posted by aknovaman
I am out of town and cant verify with my ibooster sensor but does this look correct?
https://www.amazon.com/Davitu-Cables...08918QR4V?th=1
https://www.aliexpress.us/item/22558...andl_shipto=US
Borrowed from another forum but here is some part numbers.
Its just missing the plugs/ seals
ibooster gen1 connectors:
bosch
large conector: 1928405762
cover: 1928405765
pins: Bosch BTC Terminal
1928498807
1928498806
1928498705
small connector: 1-967640-1
pins: 5-965906-5
Looks like Mouser carries the small connector and terminals but not the large connector.
Andrew
Old 01-25-2023 | 06:26 PM
  #42
aknovaman's Avatar
https://www.alibaba.com/product-deta...173797924.html
$5 dunno about shippping.
https://store.chiefenterprises.com/1...8aAsR2EALw_wcB
$16.30
Old 01-25-2023 | 06:53 PM
  #43
I would never get anything from AliBabba. It's all Chinese counterfeit stuff.
Andrew
Old 04-20-2023 | 02:06 PM
  #44
Novapat67's Avatar
Originally Posted by ryeguy2006a
I wonder if you can remove that plastic cap and get a regular fill reservoir. Or if you can just swap that MC for a tesla unit that has a regular reservoir like Andrew's.
I have done some experimentation with this and a reservoir from a Chevy Volt fits the CRV master well, looks a lot better, and has a regular cap. You just need to trim off a little plastic nub with a utility knife and it works. Takes about 2 min and is very obvious/easy. The ports and set screw are the same as well.
Old 04-20-2023 | 02:08 PM
  #45
Novapat67's Avatar
2016 Chevy Volt master reservoir is fairly horizontal.
You can also clock the master so it is not at an angle and drill and tap the booster. I have done this and it works just fine. I can post up a pic if you want. This is the same reservoir you can use on the CRV master.
The following users liked this post:
Project GatTagO (04-21-2023)
Old 06-02-2023 | 03:23 PM
  #46
JPnTX's Avatar
Default Gen 2 iBooster installs
Works really good. I'll never use vacuum again
The following 2 users liked this post by JPnTX:
Project GatTagO (06-03-2023), ryeguy2006a (06-05-2023)
Old 06-02-2023 | 03:33 PM
  #47
ryeguy2006a's Avatar
Hmmm... that's very interesting that a stock style MC will fit. Can you share what modifications were necessary for that to work together? Looks very stockish with that gen2 unit.
G Atsma (06-02-2023)
Old 06-02-2023 | 03:36 PM
  #48
TrendSetter's Avatar
ive been driving mine for a while now and its great. as for fitting a stock type master, its just a matter of adapting the bolt pattern. its still just a pushy-helper whether its vacuum, hydraulic or electric.
ls1nova71 (10-04-2024)
Old 06-02-2023 | 04:04 PM
  #49
JPnTX's Avatar
Trendsetter is correct. You need an adaptor to clock the master cylinder to horizontal. The studs on the iBooster are more like 45 degree. Additionally you'll need a machined insert to account for the difference in pushrod depth. The rod
is recessed in the iBooster housing, not flush with the mounting flange like a vacuum booster
Old 06-02-2023 | 04:07 PM
  #50
i clocked the whole booster on my car to make it fit more to my tastes
Old 06-02-2023 | 06:36 PM
  #51
dsmless's Avatar
Default Ibooster
I just subscribed to this forum to say thank you for helping me get this same idea rolling.
I do not have a chevy anything but I do have a liking for using new tech and fabricating stuff.
I used the same option of a clutch master cylinder that drives a clutch slave that actuates a gen 2 ibooster thats mounted up by the firewall in a fabricated by me aluminum cage. Thats mounted on the trans tunnel. (70 mustang with 5.4dohc swap).
I still gotta run the brake lines to my prop valve and bleed the brakes but at least these pics can be of help.
Ibooster bleeding was easy as hooking it up tona 12v cordless battery and pushing the pedal.
Hope these pics can help
someone thats looking for ideas. I know I learned alot from seeing the remote mount pics.
Old 06-02-2023 | 07:20 PM
  #52
JPnTX's Avatar
The Gen 1 booster is really good option as well. It’s clocked in a way to allow reusing the Bosch master so ends up being a little more compact.
kevin4578 (06-05-2023), Project GatTagO (06-03-2023)
Old 06-05-2023 | 07:49 AM
  #53
kevin4578's Avatar
What vehicle is that from?
Old 06-05-2023 | 09:34 AM
  #54
JPnTX, you may have a market for those brackets and push rod extensions. You should sell them as a kit! Also, I'm assuming that there is a custom bracket in the rear that allows for it to be bolted to GM cars. I see Chevrolet script on the two valve covers.
Old 06-05-2023 | 09:37 AM
  #55
JPnTX's Avatar
Tesla and Honda both used Gen 1 boosters extensively. I'd imagine there are other manufacturers that did as well.
Old 06-05-2023 | 09:39 AM
  #56
JPnTX's Avatar
bobcratch (06-07-2023), ryeguy2006a (06-05-2023)
Old 06-05-2023 | 10:28 AM
  #57
Parker Lewis's Avatar
JP, is that your kit? That's some good looking stuff. Good idea to space the booster out away from the firewall, I think I need something similar for my project so the booster doesn't hit the steering column/shaft.
Old 06-05-2023 | 10:32 AM
  #58
aknovaman's Avatar
I think we are wondering what the master cylinder and reservoir are from.
Old 06-05-2023 | 10:37 AM
  #59
JPnTX's Avatar
You're exactly right Parker. That's a `67-'72 C10 kit. Worked really hard on a direct to firewall solution but never could get around column interference.
Old 06-05-2023 | 10:38 AM
  #60
JPnTX's Avatar
That particular booster/master/reservoir are all Tesla model S.
