View Poll Results: Are you interested in swapping the ZF8HP transmission?
Yes, I am interested!
136
83.95%
I am unsure.
16
9.88%
I have no idea what you're talking about.
10
6.17%
Voters: 162. You may not vote on this poll
ZF8HP Transmission swap
I have a customer project going now: 65 Malibu, Speedtech chassis with IRS, LT1, ECU Master PDM, etc. Unfortunately, we've already purchased a 4L70-E (that's what happens when you buy parts too early!). Andrew's ZF8HP setup would be a far better choice. I've got easy programmability with the ECUMaster PDM. Sigh. I'll be chatting with my customer about this. Thanks Andrew, for making life difficult for us car builders.
I didn't read the whole thread. But recently installed a 8hp behind a 5.7hemi using the controller from Russel Drake at Sound German in Bellevue WA. It was honestly plug and play. The transmission controller is completely stand alone and could be ran with any ECU, it just uses the standard inputs like any TCU. Support is out standing. Russell was easy to get ahold of and we will use his stuff in the future.
It didn't require any hardware changes to the transmission.
For someone who is looking into paddle shift options for a purely road race car, this thread is great. Andrew's work is fantastic.
Question: If I only wanted a purely manual shift setup with the ZF8HP (no automatic mode) does that significantly simplify the programming process and/or the amount of controller hardware required? The shifting would be electronic switch controlled (like DIY paddle shifters).
Background: I have a heavily track prepared road-racing Miata (not much Miata left) with a LS swap and a dog box T56. I have campaigned it in NASA ST/TT. Going to a pure paddle shift option would be very attractive, and I can handle all of the mechanical and wiring work. The big unknown for me is the transmission controller programming, and I have no desire to go down that rabbit hole; I have enough to do as it is.
Right now the car is using a EFILive flashed GM PCM to control the motor; however I am about to upgrade to a Haltech R3 which has a can bus that is NOT proprietary (like a Holley is from what I understand).
I saw the comments about direct control with the MaxxECU but I was not clear on whether the TurboLamik was still required or not. Also since MaxxECU is new in the game, I would feel much better with a Haltech.
Thanks
Thanks
Thanks
Thanks
You could do that--it actually won't change very much--there are 8(or 9) settings in which you can select different drive modes and P8 is all manual(although it does downshift automatically, that is something you could turn off).
My DCT is just microswitches that ground to make the shift.
If you have MAXXECU you do not need turbolamik
I am unsure how the haltech would work. Holley is now fully functional with turbolamik(firmware was just released like 3 days ago too!)
Thanks
Thanks
On your second point, are you saying that within the context of the ZF8 or are you referring to a BMW DCT? If you are just talking about paddle shifter controls in general, yes that part is pretty simple.
https://www.maxxecu.com/webhelp/advanced-8hp.html
The Maxx strategy is different than other options on the market. They retain the stock TCU, but they flash it with their own firmware. In order to change the transmission settings you need software called MTune. People read stuff on the internet and spread claims without fully understanding the details. Details matter.
I am obviously biased towards Holley EFI, and I can honestly say that what I have done with TurboLamik works very well. I have no doubt that Haltech and Maxx systems work well, but getting support is the most important part of any system. I have made it my business to be the GO TO person for both Holley EFI and TurboLamik tuning.
Andrew
100%, and thanks for establishing so many.
So there are at least two paths covered here for the 8HP:
- MaxxECU for ECU and TCU, no additional TCU needed, but the transmission control is in Beta (possibly sketchy?).
- Holley EFI and TurboLamik TCU with established tuning (?) but considerably more $ for hardware.
This leads me more toward keeping my existing T56 dog box and waiting for the 8HP path to become more established and hopefully less expensive (hardware + trans + adapters + trans cooler + etc = $$$) . Other considerations (for me) are the T56 is already in the car and working very well, and the 8HP is about 50 lbs heavier than the T56; this matters for road racing. Plus fitting an 8HP into a LS swapped Miata, with adequate ground clearance, may not be trivial.
Thanks. I have seen Maxxecu mentioned here and there so I will check it out.
On your first point, are you saying these are modes in the Turbolamik?
Which is effectively how your paddle shifters would work--one for up and one for down.
You could actually have both with turbolamik. After working with Andrew on this, it is definitely an amazing system.
I took my car out saturday morning to do one final shake down before I get some videos and boy does it drive nice! 3-4,4-5 shifts are soo much fun at WOT
This thing from a roll on would
all over the 489 big block and 6 speed tremec I had in the car.100%, and thanks for establishing so many.
I got my 8hp for 500 bucks
The adaptor and computer were expensive.. but I can use those on other 8hps in the future
This is not any more expensive than doing a 6 speed or 4l80 swap if you're making decent power as you have to build those to handle it where this does right out of the junkyard(so far)
Now if you ALREADY have a decent 6 speed then there's the only advantage is shift speed and gearing.
It's not much heavier in the sense that you have a bell housing, clutch, flywheel and all that you would need to account for.
- Good point on the weight. Not needing the clutch, flywheel, and pressure plate removes a lot of weight. I presume one still needs a pressure plate and the input shaft adapter but those are not as heavy as the aforementioned.
- I could sell the T56 as it is worth some significant money being freshly rebuilt and faceplated, so there is some cost offset.
- Looks like around here they are going for $750 for a good one with lower mileage (less thank 100K). Still that is inexpensive.
To be fair:
It depends on how you're going to use it. I am using the factory torque converter too. I got mine for 500 bucks with 33k miles!
I basically sold my 4l80/circle D converter for a little less than what I have in this build, and it was completely worth the extra cost(I would say I have an extra 1200-1500 bucks in this going in knowing this is on the bleeding edge of people doing it which means prices might come down if it becomes more mainsteam) . The 4l80 felt super sluggish with this build compared to the 8 speed. It's night and day difference.
OK after reading some of the information on the MaxxECU I have questions for someone (if anyone) that has implemented and successfully tuned MaxxECU control of a flashed 8HP.
- How much 'tuning' of the transmission is required, other than setting up the default settings in the MaxxECU? From what I can tell, the following need to be 'tuned':
Shiftcut conditions
Retard angles
Ramp back times
Fuel and Ignition Drop
Throttle Blip and Blip Delay
- If someone has never tuned an 8HP before, how deep is the rabbit hole to get the above 8HP settings working well? I can handle tuning an engine, which took a long time to learn the first time of course. If there is a lot to learn for tuning an 8HP that needs to be considered.
Thanks
Shiftcut conditions
Retard angles
Ramp back times
Thanks
Shiftcut conditions
Retard angles
Ramp back times
Thanks
Shiftcut conditions
Retard angles
Ramp back times
Thanks
I can only speak about the Holley EFI and the TurboLamik. The trickiest part of getting the TurboLamik to work properly is imputing a good torque table. After watching the process a couple of times, I think I have a good handle on it. The torque table doesn't need to be 100% accurate, but it should be close. Given a good engine tune a decent torque table can be estimated based on fuel consumption. Right now we are using the internal torque tables inside the TurboLamik, but I am also going to experiment with sending torque values from the Holley EFI.
The torque reduction is straightforward with the TurboLamik. The TurboLamik sends a 0-100 value to reduce torque. I then create an advanced table to do the timing offsets. The TurboLamik hands the ramps.
Andrew
I don't think you will get any real answers regarding the MaXX 8HP solution here, because it is still in Beta. There is a Maxx FB group and there are several people that seem to be using the Beta software. I have not seen anyone with a LS/8HP combination with a MaXX ECU controlling both.
Andrew
Andrew
