LS1/6 Speed Trans. Crossmember Just Completed
Attached are some pictures of the crossmember I just installed in my 69 Camaro:
1) I used the stock crossmember instead of a Turbo 400 because it looked stronger and had a flat area for straight cuts
2) I basically purchased some 1/4" stock from Lowes (12" x 4") and welded these to the sides of the original crossmember. I made two welds with the last one extra wide for better penetration on both pieces. I also added two extra gussets on each side for additional strenght
3) I designed it for a three piece bolt together to ease installation and removal again using some existing 3" "C" channel with 1/4" plates welded to each end. The stock LS1 rubber mount was also used.
4) Painted them with Eastwoods Gloss Chassis paint. I used Gray Zero rust with a clear coat for the bottom floorpan
The end result turned out very nice and the cost was minimal!
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
69LS1SixSpeed,
thats a very nice design! And thanks so much for posting, I was just about ready to start fabricating my cross member and was mulling over different ideas and I think I'm now going to go with your design.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Originally Posted by 88SS LS1
SWEET!!
Have one question, didn't see a maf on your intake ducting
Chuck
Originally Posted by Mark IXZD 150
Looks good!
BTW, where'd you get that slick dual air intake tube?
Chuck
Originally Posted by svt
69LS1SixSpeed,
Chuck
im interested in that dual intake bit but i was wondering if you could get me the distance from the TB hook up to the edge of the cleaners as i am in the same predicament as you trying to fit rad/fans ...does look very good tho!
