What was your 3 biggest issues to overcome?
Thanks
2) Affordable engine mounts that set the motor in a nice location without having to send oil pans and pickups in to get work done.(A nice cast alum pan would be nice. Send your stocker in and save 200 bucks, pay the difference)
3) Nice affordable rad with fans.
4) Exhaust, Long tubes, only choice is custom built (for the 70-72 Chevelles atleast)
These are coming from someone doing a LQ4 conversion into a 72 Chevelle.
-Matt
2. Wiring up an entire engine and all new gauges. Not difficult, but very time consuming.
3. Cutting the top of my tranny tunnel off and raising it 1.5" to clear the 6-speed.
1. MONEY!!
2. Modifying just about everything to get the motor/tranny to fit - still working on the t56kit tranny x-member
3. Re-wiring the entire car from headlights to tail lights including fuel injection so that it isn't just all thrown in there.
as far as doing the swap, im blessed with the fact that the physical connections are almost a bolt in on the 3rdgen. the gauges read off of everything fine (except the tach, no biggie with a box) and the fuel system is already a high pressure EFI unit.. just add the right fittings and swap pumps. i havent had to pickup my welder once so far..
i expect the exhaust to be the biggie since i cant do it myself.. (well i COULD with premade bends and a chop saw... but im not going to...)
so far the hardest thing ive done on this swap is unbolting the nose of the car...(top corner bolts are a PAIN... i really happy, i thought this swap was going to be a total b!tch.
two reasons.. one, my car is getting a new one before it gets repainted (old one had a couple gouges... nothing bad, but nothing i wanted painted over) and two, the 91-92 cars have longer noses... so most engine hoists (mine included) hit the bottom GFX before the engine is in.
earlier cars, like my old 82 and your 83, should JUST clear.
http://www.warpten.com/carpics/ls1/DSC00030.JPG
Obviously not an option if you're dropping the engine + trans as an assembly, but this was worth the little extra hassle as it allowed me to keep the garage door shut when I was swapping last January...cold outside.
not a option for me... i never seperated the engine and trans.. they all slipped in together (quite easily i might add....)
2.Motor mounts were going to be a problem until I figured out that off the shelf Corvette brackets and mounts would fit perfectly.
3.Radiator hoses......made in several pieces because of the configuration of an early Ford radiator (you F-body guys got it EASY).
2. Trying to figure out where to relocate and modify stuff to gain more room in the engine compartment
3. Figuring out all the electrical gremlins. Newer vehicle swap so it wasn't just a get power to the PCM kinda thing.
